Looking for a specific ITX case covered on LTT
tasla
Hey y'all,
Some number of (months/years?) ago LTT covered a couple of small form factor PCs. One of them was pretty much perfectly square on the front, with a giant fan on the front, and it used green semi-transparent plastic. They lauded its cooling abilities at the time and I believe they received the PCs pre-built.
The closest comparison I can find is the Ironside Y2K, https://ironsidecomputers.com/y2k/ but only really a match in aesthetic.
I can't for the life of me find this thing - if anyone remembers the pc in question please let me know, I desperately need to build one of these things.
On 5/12/2024 at 5:22 PM, manikyath said:
this one, by any chance?
I'm guessing it's not that one. OP said a fan on the front, this has a water block or res...
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
