Help with Network Unmanaged Switch
On 7/8/2023 at 8:17 PM, Donut417 said:A NIC is a Network Interface card. While you dont have a card in your machine back in the day thats the only way to get a connection. Nowadays it's all integrated onto the motherboard. The easy way to tell what speed the devices are negotiating at is to look at the Switch. On the Right and Left side of each port is an LED. If the left side is either solid green or blinking green then its connected at 1 Gbps. If the right side is solid yellow or blinking yellow it means its at 10 Mbps to 100 Mbps. Blinking just indicates data transmission. This is directly from the TP Link manual. https://www.manua.ls/tp-link/tl-sg105/manual?p=9
However if you are on Windows 10 you can go Settings > Network & Internet > Change Adapter Options. RIght click on the adapter that is connected and select the "Status" option. That will indicated the speed.
I dont have AT&T and the documentation on their box is a bit meh. But Id assume somewhere in the web interface they will have what speed each port is operating at as well.
You only have Gigabit, I wouldn't put it past AT&T to have disabled that port because in their eyes no one that doesn't have 2.5 or 5 Gbps is going to use it. I cant say this is fact but Ive seen ISP's here in the US do stupid shit. This is the reason we dont rent Comcast equipment and choose to use our own. Try one of the Gigabit ports and check to see what speeds everything is negotiating at.
Also what kind of Ethernet cabling are you using?
Thanks for all the info and help. Ended up solving my problem with a few solutions. 1. I changed the Ethernet ports from "auto" to 1GBps in the modem settings. 2. I changed the cable out 2 more times that goes from the modem to the switch. 3. Called AT&T about the blue port not working and they are shipping me a new modem.
I believe the 3rd Ethernet cable I tried was the solution but can confirm your light trick and speed test now shoes devices on the switch getting their full 1GBps!!!
