UPS for a Synology DS923+
Solved by DrMacintosh,
18 minutes ago, ToboRobot said:
Thanks, after some digging I found this site: https://www.synology.com/en-global/compatibility?search_by=category&category=upses&filter_brand=APC
In that I found that the APC UPS that I have at home is compatible with the DS923+: https://www.synology.com/en-global/compatibility?search_by=category&category=upses&filter_brand=APC
