RGB and aRGB working together on Asrock B450 Steel Legend?
1 hour ago, Budget DIY said:I'm sure I'll be able to connect the hardware. But will I be able to sync both RGB and aRGB fans. That's the question. (the software side I suppose)
The motherboard rgb software will handle it just fine.Or your other options are openrgb or signalrgb
Featured Topics
Anonymous1234 ·
Posted in Troubleshooting0 -
CasoF13 ·
Posted in Storage Devices0 -
hanouzz ·
Posted in Power Supplies8 -
Hellowpplz ·
Posted in Troubleshooting3 -
D. Sheperd ·
Posted in Troubleshooting1 -
CGarza ·
MyLittleFella ·
Posted in Audio2 -
Renton577 ·
Posted in Laptops and Pre-Built Systems1 -
DanteCoal ·
Posted in Troubleshooting6
play_circle_filled
Latest From Linus Tech Tips:
iPhones Are Undeleting Nudes?? - WAN Show May 17, 2024
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
