Placement of top fans
Solved by Ralfi,
Do you want to use both up there? I don’t think there’s a need for two when you’ve got a mesh front panel with 3 intakes, unless you live in a hot climate, then you could add the top-front as an intake to help cool your CPU & push the GPU exhaust air away from potentially compromising the airflow entering the CPU HSF.
The one that’ll help the most is 1 exhaust fan in the top-rear.
But you can add a second in various positions/directions & see if it makes a difference in temps.
I just think 1 top-rear is all most people would need, especially if you have a hefty CPU cooler (going off pics).
