CPU_FAN header vs PUMP_FAN header?
DriedSponge
HI there,
I recently got an AIO for my computer to replace my air cooler, and I'm currently using the CPU_FAN header on my motherboard. I noticed my motherboard also has a header titled PUMP_FAN, so I'm wondering what exactly is the difference and should I be using the pump fan header instead? For reference, I have a MSI B450 TOMMAHAWK MAX and an Acrtic Liquid Freezer II 360. Thank you.
Remember to quote or @mention others, so they are notified of your reply
AMD Ryzen 9 5950X | Arctic Liquid Freezer II 360 | MSI B450 TOMAHAWK MAX | G.Skill Trident Z RGB 32 GB DDR4-3600 | Gigabyte GeForce RTX 2080 SUPER 8 GB
Samsung 980 EVO Plus 2TB | SK hynix Gold S31 500GB SSD | Seagate Barracuda Compute 2 TB 7200RPM HDD | 1TB Samsung 860 EVO SSD | 3x Phanteks T30-120
Corsair RM1000e 1000 W 80+ Gold Certified Modular PSU | Corsair 5000D Airflow Windows 11 Home
6 minutes ago, DriedSponge said:
HI there,
Use the cpu_fan. That way the fans *should* ramp up down based on cpu temp.
pump_fan header always pushes 100% I believe and is more so used for custom liquid cooling setups.
I could be wrong but this is from remembrancez
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
That's good to know, thank you!
pump pwm header usually has higher power output, 36w (12v by 3a)
compare to normal fan pwm header, 12w (12v by 1a)
check yer mobo manual too
Ryzen 5700x + EK Supremacy D-RGB | 2x8 GB DDR4 Klevv 3200 MT/s | MSI B550M Mortar | Palit 3070 GamingPro LHR + Bykski N-PT3070PRO-X | Corsair RM750 | Alphacool EPDM + QDC | Aquacomputer Quadro + HighFlow2 | EK D5 XTOP | Freezemod 360 30mm rad + Barrow Dabel-20b 360 20mm | Barrow & Freezemod fittings | Corsair 5000D Airflow
Audio: beyerdynamic DT 900 Pro X + iFi ZEN Air DAC + Razer Seiren Mini
In my motherboard manual, I didn't see anything about them other than the fact that they exist. Maybe I was looking in the wrong place.
Here's an example for the MSI B550 Tomahawk: https://download.msi.com/archive/mnu_exe/mb/MAGB550TOMAHAWK.pdf
Page 23:
Connector  | Default fan mode | Max. current | Max. power
CPU_FAN1   | Auto mode        | 2A           | 24W
PUMP_FAN1  | PWM mode         | 3A           | 36W
SYS_FAN1~6 | DC mode          | 1A           | 12W
oof.... if they don't list it in the manual, then it should be just 1a
