units of sound
goatedpenguin
When you are increasing the sound by x number of units what units does windows use to measure it ex decibles etc. here is a screenshot of what I mean:
It's SOMETIMES percentage of total volume possible, though not every instance is perfectly linear, sometimes it may functionally limit itself at something like 84%.
I think it depends on the audio device. I have some crappy speakers that have 0 as set to off and any value from 1-100 set to max volume for some reason. If I am watching youtube I have to use the volume slider on the video to adjust audio.
My PC Specs: (expand to view)
Main Gaming Machine
CPU: Intel Core i7-10700K - OC to 5 GHz All Cores
CPU Cooler: Corsair iCUE H115i RGB Pro XT (Front Mounted AIO)
Motherboard: Asus TUF GAMING Z490-PLUS (WI-FI)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600
Storage: Intel 665p 1 TB M.2-2280 NVME SSD (x2)
Video Card: Zotac RTX 3070 8 GB GAMING Twin Edge OC
Power Supply: Corsair RM850 850W
Case: Corsair 4000D Airflow
Case Fan 120mm: Noctua F12 PWM 54.97 CFM 120 mm (x1)
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x4)
Monitor Main: Asus VG278QR 27.0" 1920x1080 165 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
I once encountered a yamaha receiver where it went from 0-infinity and infinity was silent, 0 was blown eardrums
Windows 10 volume doesn't correspond to any meaningful units that I can think of. The scale is neither linear (voltage) nor logarithmic (dB).
oh ic so there no definite way of telling without a third party software thanks for the help 🙂
It's basically a percentage compared to full volume. As noted below by independent testing, it's not perfectly linear, but it's pretty close.
Also, it's different with every single computer, and every single speaker, so it does not correspond to any unit of measurement.
You can find out how exactly it works on your specific computer with your specific speakers, assuming you have a sound meter to measure with.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
so if I knew the max sound of the headphones can output I can find the percentage per decibels since it is close to linear it would be negligible or no?
max voltage your amp can output and how that translates to db with your headphone's impedance and sensitivity. headphones are not smart systems and they will go as loud as the amp forces power into them. well until they pop.
the exception being if you have a bluetooth headphone or some other headphone with a built in amp
