Hello,
I ran a benchmark for the new COD MW II and it says my CPU is 99% bottlenecking my GPU.
Specs:
CPU: Ryzen 9 3950X 16-core 3.50 GHz
GPU: RTX 3080 Ti
RAM: 16gb DDR4 3600 MHz
Monitor resolution: Samsung G7 1440p QHD
Can I please have some advice how to unlock the remaining FPS from my GPU.
Thank You.
2022-11-01 21_52_15-C​a​l​l​ ​o​f​ ​D​u​t​y​®​ ​H​Q​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​​.png
https://linustechtips.com/topic/1464839-bottleneck-help/
11 minutes ago, CRBN said:
Hello,
Specs:
GPU: RTX 3080 Ti
Thank You.
I see you're using DLSS, i would re-run the test on native resolution: 2560x1440, this should put more load on the GPU and make the ''bottleneck'' less.
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
https://linustechtips.com/topic/1464839-bottleneck-help/#findComment-15634262
I'd like to thank Activision from the bottom of my heart for teaching the term "bottleneck" to more people so they can misunderstand the concept and wring their hands over it. 🙄
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1464839-bottleneck-help/#findComment-15634266
*Krusty the Clown* Uuuuuugggggggggghhhhhhh...
"Don't fall down the hole!" ~James, 2022
"If you have a monitor, look at that monitor with your eyeballs." ~ Jake, 2022
https://linustechtips.com/topic/1464839-bottleneck-help/#findComment-15634402
I did this, it made a 50% difference, thank you. I always thought my CPU was good, should I be upgrading to the ryzen 9 7950x?
Is there a way to get to 0% bottleneck without upgrading my CPU?
https://linustechtips.com/topic/1464839-bottleneck-help/#findComment-15645640
upgrading is upto you, if you're happy with the performance then don't, i'm sure by now there are plenty of benchmarks out there comparing your cpu with the newer stuf you can check out.
yes but you'll probably have to play at 4k to get close to 0% bottleneck in this test.
I wouldn't worry to much about bottleneck as there will always be one.
https://linustechtips.com/topic/1464839-bottleneck-help/#findComment-15645670
The problem is for some weird reason, if i select max max settings for graphics or even low settings for graphics; i still get the same fps (~80 ingame). I have turned the fps limit to unlimited. I don't understand, shouldnt my fps increase if I select low settings?
https://linustechtips.com/topic/1464839-bottleneck-help/#findComment-15645918
