Upgraded CPU no Post, Downgraded again no Post
Solved by Sloptok,
Operation completed successfully!
I used a special plastic adhesive to glue the pins back on the shelf part.
Then I heated the shelf to carefully bend it back down a little bit.
While installing the CPU I kept pressure on the edge of the shelf part (just to be sure) because there still was a little gap between the two parts, but ...
Everything works fine!
If anyone has the same problem and isn't afraid of tinkering a bit. Just be very gentle when pulling up the sliding cover. The locking mechanism isn't intended for multiple disassemblies and is very fragile. I had to glue them, too.
Best of luck to you!
