okay so im just going to post the assignment itself, cause im a super noob with c. i am extremely fluent in java and i have a basic ability using MIPS and the class started doing C now.  i have literally no clue how to do most of the things in c... i could wwrite the entire program in java with no problem lol. Pointers *& kinda confuse me. i dont have syntax down either.
heres the assignment:
In this lab you will write a C program to sort an array of strings. The program will:
  • Create an array of 50 strings; each string can hold up to 30 characters.
  • Write a function to read strings from the file "strings.dat" into your array. Read until EOF and keep track of how many strings you read, as it may be less than 50. Then pass this variable to your print and sort functions so they know how many strings to print and sort. Use fopen to open the file and fgets to read each string.
  • Write a function to sort the strings. Only sort the array entries that contain strings read from the file. See below for pseudocode for selection sort.
  • Write a function to swap two strings, which will be called by your sort function. Pass the array and the subscripts of the two strings that need to be swapped.
  • Write a function to print out the array entries that were read into the array. Use printf.
  • Your main function should call the functions to read into the array, print the array, sort the array, and print the array again.
Selection Sort
for (last = numstr-1; last >= 1; --last) {// select largest item in arr[0..last]loc = indexOfLargest(arr, last+1);// swap largest item arr[loc] with arr[last]swap(arr,loc,last);}int indexOfLargest(arr, numElements){indLarge = 0; // index of largest item found so farfor (curr = 1; curr < numElements ; ++curr) {if (arr[curr] > arr[indLarge])indLarge = curr;}return indLarge;}
Hints
  • Look up fopen. You will use "r" for the mode parameter; this opens the file for reading. The FILE pointer returned by fopen is used as a parm for fgets so that it reads from your file.
  • Look up fgets. Remember that fgets stores the newline in the string if it sees the newline before it reads n-1 characters (n is one of its parms). After the newline it adds a null byte.
  • fgets returns NULL when it reaches end of file.
  • After reading each string, remove the newline if it is there. If there is a newline, it will be in the next-to-last position of the string (right before the null byte). Use strlen to find the last position. If there is a newline, replace it with a null byte.
  • In C the constant for null is NULL. This constant is defined in stdio.h, as well as other header files. It must be written in all caps.
if anyone can help me with this i would really appreciate it.
also; what do you guys use to compile c... the class uses dev c++ but whenever i run the console for c apps on my laptop in devc++, devc++ stops responding... sooooo....
thanks guys xD - Joe
Edited by alpenwasser
code tags
https://linustechtips.com/topic/145806-help-with-c-class-please/
In windows mingw is pretty straight forward. I use it with the C edition of eclipse. Google for a setup guide.
C in Linux is easy, install gcc, and just compile with gcc <file>.c -o <fileName>
For sorting, I would use a bubble sort. It's horribly inefficient but really easy to write.
Create a swap function that takes 2 inputs, that will swap the pointers (easiest) or swap the data between two strings. If you decide to swap the data don't forget to call free after malloc. Both ways will require a temp variable.
Iterate over your array of strings and strcmp (string compare) i with i+1. If i is > i+1 then call your swap function to swap i with i+1, then increment i by 1. Repeat this process till you read the end of the array, if you had to call your swap method even one time, then your array is not sorted. Repeat the process above until no swaps have been made.
After that your array will be sorted.
EDIT: your teacher gave you pretty much everything you need to use selection sort. Just keep track of how many lines you read from the file and use your swap function to swap the largest with the last element. The variable last is decremented for you.
Your teachers swap method takes 3 inputs, the array, and 2 indexes. Same methodology applies though, swap the pointers or the dat.
http://www.geeksforgeeks.org/swap-strings-in-c/
http://www.phanderson.com/files/file_read.html
https://linustechtips.com/topic/145806-help-with-c-class-please/#findComment-1946955
im on windows 8.
cant use bubble sort, believe me i would, selection is mandatory but like you said its all there. im just having trouble grasping the concept of how to fill the array from the file using fscanf im assuming... and also the fget as well? not really sure how to use either of them properly
https://linustechtips.com/topic/145806-help-with-c-class-please/#findComment-1946969
im on windows 8.
Look at the 2nd link at the bottom of my post above.
I have windows 8.1 as well, no issues for me using mingw and eclipse for C. The new versions of eclipse auto-detect any installed compilers. You just need to make sure you choose mingw as your compiler when creating a new project
https://linustechtips.com/topic/145806-help-with-c-class-please/#findComment-1946981
ty im in the process of installing minGW now
https://linustechtips.com/topic/145806-help-with-c-class-please/#findComment-1946996
You need to be careful when using other compilers from the rest of the class.
Some compilers are smarter than other (gcc) so something that compiles fine with gcc might not compile with mingw. Or vice versa.
Some teachers want you to use a certain compiler, and others don't care. Send him an email and check if it's okay.
Otherwise I'd rough it with the udev compiler you mentioned above
https://linustechtips.com/topic/145806-help-with-c-class-please/#findComment-1947004
yeah it was just hard to try using dev c++ because i cant freaking test anything... oh well more on that later i guess. i gotta get the dang coding part done
https://linustechtips.com/topic/145806-help-with-c-class-please/#findComment-1947031
Use Code::Blocks. It comes with MinGW and is already configured. Dev-C++ sucks, really.
http://www.codeblocks.org/
That said, it's probably choking on the fact you put a space in your file name.
main(i){for(;i<101;i++)printf("Fizz\n\0Fizzz\bBuzz\n\0%d\n"+(!(i%5)^!!(i%3)*3)*6,i);}
https://linustechtips.com/topic/145806-help-with-c-class-please/#findComment-1949900
so does dcpp i tried codeblocks first. something wasnt working. ill try again
https://linustechtips.com/topic/145806-help-with-c-class-please/#findComment-1949927
did you install mingw? did you install it in a custom path? if you leave it on c:/mingw, codeblocks should detect it right away
edit: did you run mingw to download the gcc compiler using the mingw packages installer?
edit again: nevermind, i didn't read your last post
https://linustechtips.com/topic/145806-help-with-c-class-please/#findComment-1950204
dont mean to spam my own post, but i got it. i realized i didnt install the code::blocks mingw version. well codeblocks works now. now how the heck do i get the program to read in the required strings from a .dat file?
int main(){    FILE *read;    read=fopen("something.dat","r");    if(read!=NULL)    {        char *s=malloc(10*sizeof(char));        fscanf(read,"%s",s);        printf("%s",s);    }    return 0;}
https://linustechtips.com/topic/145806-help-with-c-class-please/#findComment-1950323
^.^ lol okay well so far i have a basic outline of just reading in strings from the file into an array. not entirely sure on how to error check for the 30 character per string limit, but ill get to that later i guess.
https://linustechtips.com/topic/145806-help-with-c-class-please/#findComment-1950325
what does the s pointer = malloc do/mean?
what i have so far:
#include <stdio.h>#include <conio.h>int main(){    FILE *pFile;    char strings[51];    int i;    //Open File    pFile = fopen("Strings.dat", "r");    if (pFile != NULL)    {        while(!feof(pFile))        {            fgets(strings, 51, pFile);            printf("%s", strings);        }        fclose(pFile);    }    return 0;}
https://linustechtips.com/topic/145806-help-with-c-class-please/#findComment-1950337
