PSU Capacitor Exploded - Cause?
Solved by Spotty,
2 minutes ago, danomicar said:Sure thing, photos are below. You are correct that it is an NTC component. I believe it says NTC 50-15.
The NTC thermistor is used on the primary side (AC input) to limit inrush current spikes. I'm not entirely sure what would have caused it to blow open like that. The good news is at least since it is on the primary side that means it's unlikely the rest of the system was damaged.
Good lesson not to cheap out on power supplies I guess.
