Is there an 1050ti Cooler Mounting to VGA cooler mounting adapter?
Solved by BobVonBob,
4 minutes ago, TitanfallAddict said:The Morpheus II is VGA and I don’t know what the 1050ti is.
"VGA" has nothing to do with mounting hole dimensions, but presumably you mean that the holes on the brackets don't line up with the holes on the 1050 Ti.
The reason the person on Reddit probably had it work correctly is because while the 1050 Ti's cooler mounting holes are 48 mm apart, some versions also had a second set of unused holes 58 mm apart, which would be compatible with the cooler. In your case, you'll either need to modify the bracket or use a jankier mounting method (zip ties et al.).
