CPU (i7-4910mq) Keeps Throttling Down to 800MHz Unnecessarily
Solved by unclewebb,
Your problem is a common one.
Use ThrottleStop to disable BD PROCHOT. Set the FIVR Non Turbo Ratio to 1.
Post screenshots if you need help.
Featured Topics
shift8 ·
Posted in Networking2 -
Premoz1 ·
Posted in General Discussion3 -
4
2
Cheki ·
Posted in Troubleshooting2 -
5
4
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
