What is your current case? "Cases statistical study"
Hello guys.
First of all, i already checked the other topics, there are some that have similar title but this is different in context, so please refrain from " this is a repost" replays.
I need you guys to tell me what case are you using at the moment, because i want to see how many people use each case, i will be posting the results in charts when ever i have some big number of replays " i will be updating the results as much as i can later as well".
so here is how you post your case information, " if you have more than one case that you use, please mention the information for all of them".
Use this template please:
________________________________________________________________________________________________
                                     | First Case |
Case Name/Model:   "write the full name or model of the case"
Year of purchase:     "the date that you purchased the case on"
Usage duration:        "how long you have been using the case"
Is the case painted:  " yes/no, if it is custom painted which color"
Is the case moded:   "yes/no, if your answer is yes, then please tell me which part and post a picture if you can"
"if you have a second case use the same template and post the info under the first case"
Please do not post twice so i can count the post easier, if you forgot something, just simply edit your post.
Huge thanks goes to any one that contribute with this post in a professional way. :)
Case Name/Model: Corsair 200R
Year of purchase: 2013
Usage duration: 1 year
Is the case painted: Do you mean like custom painting?Then no.If you're talking about what colour the case is painted,then black(interior included)
Is the case moded: No.At least not for the moment.If I ever decide to go watercooling then I'll have to drill 2 more holes in the roof to offset the rad a little more.
   | First Case |
Case Name/Model:   Cooler Master HAF X
Year of purchase:     March 2011
Usage duration:        over 3 years
Is the case painted:  no
Is the case moded:   no
My PC CPU: 2600K@4.5GHz 1.3v Cooler: Noctua NH-U12P SE2 MB: ASUS Maximus IV RAM: Kingston 1600MHz 8GB & Corsair 1600MHz 16GB GPU: 780Ti Storage: Samsung 850 Evo 500GB SSD, Samsung 830 256GB SSD, Kingston 128GB SSD, WD Black 1TB,WD Green 1TB. PSU: Corsair AX850 Case: CM HAF X. Optical drive: LG Bluray burner  MacBook Pro, Hackintosh
                                     | First Case |
Case Name/Model:   NZXT Phantom 820
Usage duration:        since then
Is the case painted:  Gunmetal gray
Is the case moded:   just little parts, nothing special
                                     | Second Case |
Case Name/Model:   Fractal design Node 304
Year of purchase:     2014
Is the case painted:  white
Is the case moded:   not yet
Case Name/Model:   Coolermaster HAF X
Year of purchase:    2010
Usage duration:        4 years
Is the case painted: The standard black colour. No custome paint job
Is the case moded:  The HDD cage has been drilled out, and the back I/O for the hot-swap bays removed. This is so that I can fit a 360mm rad in the front.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
  | First Case |
Case Name/Model:   Black Case-51W Window Case/CS51WBK
Year of purchase:    August 2010
Usage duration:        3yrs, 9mo
Is the case painted:  Stock Black Powder coat
I don't see why you need more information than just which case we're using, but I'll bite...
Case Name/Model:   NZXT Source 210 Windowed
Usage duration:        About 4.5 Months
Is the case painted:  No... but I bought the black version.
Is the case moded:  Not yet.
"A picture is starting to form here... I wonder if it's accurate? Some pieces don't quite seem to fit. Or maybe I just don't like the way it looks."
                                     | First Case |
Case Name/Model:   Cheapo no-brand generic ATX mid-tower
Year of purchase:     August, 2012
Usage duration:        Since purchase. nearly 2 years by now
Is the case painted:  No custom painting. Stock black powder coat on the outside, plain metal (aluminium?) on the inside
Is the case modded: Cut a small part of the case to fit another 8-pin connector to my GTX 590 (picture of the small "mod" bellow)
The (ghetto) "mod" to the case:
Never trust my advice. Only take any and all advice from me with a grain of salt. Just a heads up.
Case Name/Model:   Thermaltake v9 Black edition
Year of purchase:     2011
Usage duration:        3 years 6 months
9800X3D - NH-D15S - MSI X670E  -  32GB 6000MHz CL30 - RTX 3080 FTW3 - 970evo 1TB - 980pro 1TB - 970evo 1TB - 970evo+ 2TB -  970evo+ 2TB - 850evo 250GB - WDblack 1TB - WDblue 3TB - HX850i -  27GR95QE-B.AEU - 28MQ780-B - 27GP850-B - 27GL850 - Meshify 2
Case Name/Model:  Its a random "El Cheap'o" no name brand case that i got with a used crappy system.
Year of purchase:   idk some time in december
Usage duration:  6 months
Is the case painted:  nope
Is the case moded: somewhat. Siliconed a fan onto a air intake.
I dont really know what brand it is, but it originally had Foxconn parts and stuffs in it so i think its that kind.
Blue LED fan :P
My Car: http://linustechtips.com/main/topic/274320-the-long-awaited-car-thread/?p=4442206
CPU: i5 4590 |Motherboard: ASRock H97M PRO4|Memory: Corsair Vengance 8gbs|Storage: WD Caviar Blue 1TB|GPU: ZOTAC GTX 760 2gb|PSU: Thermaltech TR2 500W|Monitors: LG24M35 24" & Dual 19"|Mouse:Razer DeathAdder 2013 with SteelSeries Qck mini|Keyboard: Ducky DK2087 Zero MX Red|Headset: HyperX Cloud|Cooling: Corsair 120mm blue LED, Lepa vortex 120mm, stock 120mm|Case:Enermax Ostrog Blue Windowed
hey is this the NSA ..,,,, :)
Case Name/Model:   NZXT  phenom  420
Usage duration:        8 months
Is the case painted:  yes dark black
Manners Maketh Man
Case Name/Model: Rosewill Challenger
Year of purchase: October 2011
Usage duration: Octber 2011- now (3 years[soon])
Is the case painted: No (planning on painting front bezle)
Is the case moded: No (planning to mod drive cage)
CPU: AMD FX 8320e | Mobo: Gigabyte GA‑78LMT‑USB3 | Cooler: Cooler Master Hyper n520 | RAM: 8Gb @ 1333MHz
GPU: Gigabyte GTX 1060 mITX | PSU: Antec HCG 520w | Storage: Sandisk 120GB - WD Red 1TB | Case: Modded IBM A50 sleeper
All displayed on an AOC I2421VWH
 | First Case |
Case Name/Model:   Cooler Master CM690 (the non USB3 version)
Year of purchase:     Q3 2011
Usage duration:        Close to 3 years?
Side note: I would want to upgrade to a better case though.
|| MY HUMBLE RIG ||
|| INTEL CORE i5 2500K || COOLERMASTER HYPER 212 PLUS || ASUS P8Z68-V PRO || KINGSTON HYPER-X 8GB || ASUS STRIX GTX 970 || SANDISK ULTRA PLUS 128GB SSD || SAMSUNG SPINPOINT F3 1TB || CORSAIR HX750 750W || LITEON 24X DVD-RW || COOLERMASTER CM690 ADVANCE || DELL U2414H || LEOPOLD FC200RT/AB TENKEYLESS CHERRY MX BROWN || RAZER IMPERATOR || RAZER GOLIATHUS SPEED || WINDOOWS 10 64BIT ||
  | First Case |
Case Name/Model:   Caselabs Magnum M8
Year of purchase:     Feb 2014
Usage duration:        ~3 months
    | Second Case |
Case Name/Model:   Corsair 650D
Year of purchase:    July 2012
Usage duration:        16 months or so
  | Third Case |
Case Name/Model:   Thermaltake Level 10GT
Year of purchase:     December 2011
Usage duration:        Since Jan 2012 when I was finished with the build
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
Corsair Obsidian 750D
Purchased in 2014
No paintining, nor mods
CPU: Intel core i7-4770 --- CPU Cooler: Corsair H105 --- GPU: Asus Geforce GTX 970 Strix --- MB: Asus Maximus VI Hero --- RAM: Corsair Vengeance Pro 16GB
Case: Corsair Obsidian 750D --- PSU: Corsair AX860i --- SSD: Seagate 120GB --- HDD: Seagate 2TB + Toshiba 1TB --- ODD: Asus External DVD-R
Keyboard: Razer Blackwidow 2013 Ultimate --- Mouse: Logitech G602 --- Mousepad: Corsair Vengeance MM600 --- Monitor: LG 29UM65
  | First Case |
Case Name/Model:   Cooler Master CM 690 II Advanced
Year of purchase:     Jan 2010
Usage duration:        Q1 2010 - Q1 2013, Q1 2014 - in use
  | Second Case |
Case Name/Model:   Fractal Design Define R4 Window Edt.
Year of purchase:     March 2013
Usage duration:        March 2013 - March 2014 (R.I.P)
Case Name/Model: v9 something
Usage duration:      3months
Is the case painted: stock black
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
                                     | First Case |
Year of purchase:     June 2011
Usage duration:        2 years, 10 months
Is the case painted:  Stock black w/ red painted drive caddies, tool-less drive mounts, exterior trim
Is the case modded:  Custom full-sized window, custom LED lighting, custom SSD bracket, minor chassis cutouts
                                     | Second Case |
Case Name/Model:   Bitfenix Ronin
Year of purchase:     December 2013
Usage duration:        4 months
Is the case modded:   No
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
Year of purchase: 2012
Usage duration: 1 Year
phanteks enthoo pro | intel i5 4690k | noctua nh-d14 | msi z97 gaming 5 | 16gb crucial ballistix tactical | msi gtx970 4G OC  | adata sp900
