In  general, thermal grizzly and mx4 are the best.
For pasta, I think ravioli's would do the job quite well
Specs: 11700 | RTX 3060 | 32gb 3200mhz | 1tb 970 + 2TB HDD | Lian Li O11D Mini X Black
I'm 15 and live in the US
https://linustechtips.com/topic/1434607-thermal-pads-and-paste/#findComment-15419633
I think there may be a translation error here
Paste - Thermal paste, tooth paste, grease, etc.
Pasta -
How to Cook Pasta Like a Pro - Jessica Gavin
Now to answer the question; pastes will generally perform better than pads, but pads are somewhat reusable and last longer. For most users, paste is the better option because by the time the system needs new paste, it's probably worth replacing anyways (the system itself)
As far as best paste, Thermal grizzly is some of the best on the market, but Noctua NT-H1/H2, Artic MX4 are also good pastes to use.
https://linustechtips.com/topic/1434607-thermal-pads-and-paste/#findComment-15419639
50 minutes ago, StormBreakes said:
Hallo,
I tryd to search what is the best thermal pads and paste for GPU 3080/90.
My search get different results.
Pads:
SYY
Thermalright
Gelid
Artic
BSFF
Paste
Thermal Grizzly
BSFF
SYY
MX-4
is there any how the top winner?
For pads I use Gelid Ultimate. I have not been able to find any with better specs.
But they are not made for reuse. They break easily.
https://linustechtips.com/topic/1434607-thermal-pads-and-paste/#findComment-15419719
