Going to upgrade to 1440p but wondering about Panel types
Insomniazz
So I think I'm finally ready to make the jump to 1440p gaming since i finally got a graphics card (nvidia). I currently use a 1080p TN monitor and wondering if I should stick with TN or go with ips. I play a ton of different genre of games. I was currently trying to decide between these two monitors. I'm pretty sure they are the same other then the panel type and the refresh rate is a bit lower on the tn monitor. Also if you have a better suggestion for a 1440p monitor post it below I will check it out.
https://www.bestbuy.ca/en-ca/product/asus-27-qhd-165hz-ips-led-g-sync-gaming-monitor-vg27aq/13819629
https://www.bestbuy.ca/en-ca/product/asus-tuf-27-qhd-155hz-tn-led-gaming-monitor-vg27bq/13819628
I prefer IPS panels, TN panels have terrible viewing angles but are usually a bit cheaper at the same specs. I would also look for a non-glossy finish. I have a glossy monitor and I have a window diagonal to it and if it's summer, I can easily see that window reflected in the panel. It can be annoying
There is absolutely no reason whatsoever to go with TN panel unless you're in the lowest tier of budget. Even the cheapest IPS will still be way better than TN. Considering the links you posted and prices, you would have to be insane to go with the TN one.
For super competitive stuff, TN is still likely the best since it does have the best response times and the best refresh rates. That said, if you're sticking to 1440P 165Hz, you want to avoid it since the color reproduction on them tends to be pretty bad and they aren't cheaper enough to justify how much worse they are. A good TN panel can be pretty usable, but even a good TN looks noticeably worse than a mid-tier to high end IPS panel.
That said, it might be a good idea to look at VA panels as well. They tend to have better black levels and be bit of a middle ground between TN and IPS. Plus, some IPS panels can have a glow to them which the VA ones tend to not.
All that said, you do want to more compare specific models of monitors than just go by panel type. As eluded to above, a good TN panel will look better than a bad IPS. My old Dell S2716DG, for instance, fooled more than one of my friends into thinking it was a low-mid range IPS panel, looking better than some other cheaper IPS monitors I've used. IPS and VA usually look better than TN, but you do want to look at the specific models to see which one to go with. HardwareUnboxed is a pretty good outlet for this, rtings.com is pretty good for quick checking stuff, and there are some others.
There are some pretty nice TN panels out there. They're pretty rare nowadays, especially since IPS has gotten pretty cheap and pretty fast, but they do exist.
TN is slowly going the way of the dinosaur.
I'd recommend checking the Hardware Unboxed youtube channel and listening to their recommendations.
I should add, 32" 1440p has the pixel size of 24" 1080p so that's the better option for poor eyesight. For good eyesight or sitting closer to the screen, 27" 1440p is optimal.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
  • 2 weeks later...
Go for IPS or high grade VA. TN is always no for me and it should be stop producing now.
PC: AMD Ryzen 9 5900X, Gigabyte GeForce RTX 4090 OC 24G, X570 AORUS Elite WIFI Motherboard, HyperX FURY 32GB DDR4-3200 RGB RAM, Creative Sound Blaster AE-9 Sound Card, Samsung 970 Evo Plus M.2 SATA 500GB, ADATA XPG SX8200 Pro M.2 SATA 2TB, Asus HyperX Fury RGB SSD 960GB, Seagate Barracuda 7200RPM 3.5 HDD 2TB, Cooler Master MASTERLIQUID ML240R ARGB, Cooler Master MASTERFAN MF120R ARGB, Cooler Master ELV8 Graphics Card Holder ARGB, Asus ROG Strix 1000G PSU, Lian Li LANCOOL II MESH RGB Case, Windows 11 Pro (22H2).
Laptop: Asus Vivobook "A Bathing Ape" - ASUS Vivobook S 15 OLED BAPE Edition: Intel i9-13900H, 16 GB RAM, 15.6" 2.8K 120hz OLED | Apple MacBook Pro 14" 2023: M2 Pro, 16 GB RAM, NVMe 512 GB | Asus VivoBook 15 OLED: Intel® Core™ i3-1125G4, Intel UHD, 8 GB RAM, Micron NVMe 512 GB | Illegear Z5 SKYLAKE: Intel Core i7-6700HQ, Nvidia Geforce GTX 970M, 16 GB RAM, ADATA SU800 M.2 SATA 512GB.
Monitor: Samsung Odyssey OLED G9 49" 5120x1440 240hz QD-OLED HDR, LG OLED Flex 42LX3QPSA 41.5" 3840x2160 bendable 120hz WOLED, AOC 24G2SP 24" 1920x1080 165hz SDR, LG UltraGear Gaming Monitor 34" 34GN850 3440x1440 144hz (160hz OC) NanoIPS HDR, LG Ultrawide Gaming Monitor 34" 34UC79G 2560x1080 144hz IPS SDR, LG 24MK600 24" 1920x1080 75hz Freesync IPS SDR, BenQ EW2440ZH 24" 1920x1080 75hz VA SDR.
Input Device: Asus ROG Azoth Wireless Mechanical KeyboardAsus ROG Chakram X Origin Wireless MouseLogitech G913 Lightspeed Wireless RGB Mechanical Gaming Keyboard, Logitech G502X Wireless Mouse, Logitech G903 Lightspeed HERO Wireless Gaming Mouse, Logitech Pro X, Logitech MX Keys, Logitech MX Master 3, XBOX Wireless Controller Covert Forces Edition, Corsair K70 RAPIDFIRE Mechanical Gaming Keyboard, Corsair Dark Core RGB Pro SE Wireless Gaming Mouse, Logitech MK850 Wireless Keyboard & Mouse Combos.
Entertainment: LG 55" C9 OLED HDR Smart UHD TV with AI ThinQ®, 65" Samsung AU7000 4K UHD Smart TV, SONOS Beam (Gen 2) Dolby Atmos Soundbar, SONOS Sub Mini, SONOS Era 100 x2, SONOS Era 300 Dolby Atmos, Logitech G560 2.1 USB & Bluetooth Speaker, Logitech Z625 2.1 THX Speaker, Edifier M1370BT 2.1 Bluetooth Speaker, LG SK9Y 5.1.2 channel Dolby Atmos, Hi-Res Audio SoundBar, Sony MDR-Z1R, Bang & Olufsen Beoplay EX, Sony WF-1000XM5, Sony WH-1000XM5, Sony WH-1000XM4, Apple AirPods Pro, Samsung Galaxy Buds2, Nvidia Shield TV Pro (2019 edition), Apple TV 4K (2017 & 2021 Edition), Chromecast with Google TV, Sony UBP-X700 UltraHD Blu-ray, Panasonic DMP-UB400 UltraHD Blu-ray.
Mobile & Smart Watch: Apple iPhone 15 Pro Max (Natural Titanium), Apple Watch Series 8 Stainless Steel with Milanese Loop (Graphite).
Others Gadgets: Asus SBW-06D2X-U Blu-ray RW Drive, 70 TB Ext. HDD, j5create JVCU100 USB HD Webcam with 360° rotation, ZTE UONU F620, Maxis Fibre WiFi 6 Router, Fantech MPR800 Soft Cloth RGB Gaming Mousepad, Fantech Headset Headphone Stand AC3001S RGB Lighting Base Tower, Infiniteracer RGB Gaming Chair
I finally pulled the trigger on a 1440p ips monitor and all I can say is holy S*** makes my 1080p tn look like Vaseline
Great to know you enjoy it. 🙂
OLED-->IPS-->>high grade VA--> budget VA -----------------------------------------------------------------------------------------------------------------------------------------------------------------------> TN
AMD 7950x / Asus Strix B650E / 64GB @ 6000c30 / 2TB Samsung 980 Pro Heatsink 4.0x4 / 7.68TB Samsung PM9A3 / 3.84TB Samsung PM983 / 44TB Synology 1522+ / MSI Gaming Trio 4090 / EVGA G6 1000w /Thermaltake View71 / LG C1 48in OLED
Custom water loop EK Vector AM4, D5 pump, Coolstream 420 radiator
