Mesh system (TP Link Deco) - one ethernet for input and one for output?
Filingo
The TP Link deco has two ethernet ports:
Deco M5(3-Pack) Technical Specifications
Is one of them for the input from the wall - then it transmits wifi, and the second one for output, say for a computer/switch?
Because I need both wifi and cable, so it could be a good solution
I have these, the ethernet is for backhaul so if a cable broke it would have no downtime or issues along with second optional routes. You can plug stuff into these ports as well. So I go from my router into one then into a switch. But I also have some things plugged into the ports in other rooms.
Yes. One is modem WAN input, and one will be LAN… I assume.
Also just or note, I have had great luck with Nest Wifi (formerly google Wifi). Have it deployed at multiple family members houses and it works great.
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
Can you please provide a link to Amazon? To be sure it's the same one I saw
so it can both be from the same source as backup, and if you plug one to it for source and out from it to a PC it automatically detects it? nice
Google Nest WiFi Router – 4x4 AC2200 Mesh Wi-Fi Router with 2200 sq ft Coverage (Renewed) https://www.amazon.com/dp/B0842VS9MM/ref=cm_sw_r_cp_api_i_M3YH41RQ49J7K3ZRF6TZ
