7 minutes ago, Windows 7 lover said:
  1.
    i got windows xp virtual machine me using wifi so i want to put wifi in virtual machine me use virtualbox
  2.
Set the network connection for your XP VM to NAT or Bridged mode. That will give it access to the same networks your host OS has.
https://www.virtualbox.org/manual/ch06.html
https://linustechtips.com/topic/1569902-i-need-help/#findComment-16405636
9 minutes ago, Windows 7 lover said:
still don't understand the website
You have to go into the settings for your VM and make sure "Adapter 1" is enabled and set to either Bridged or NAT under Network.
VirtualBox Network Settings: All You Need to Know
I just grabbed this screenshot from Google Images, the interface may look a little different but should be pretty much the same.
Here's a video tutorial I found that explains it:
(Not an endorsement of this YouTube channel.)
https://linustechtips.com/topic/1569902-i-need-help/#findComment-16405695
