85c hot for a 5800x? details below.
A 129mm AIO is not suitable in any way shape or form for a 5800x. Those little 120mm AIO's aren't really any better than a single tower air cooler, and in some cases, worse. While 85C is "fine" its only really OK if you're clockspeed isn't suffering as a result. If you're maintaining 85c under a FULL load, not a gaming load, and reaching comfortable boost clocks, you're fine.
For a chip of that caliber, you want adequetly sized AIO or tower air cooler. Generally a 280/360 AIO or the current high end air coolers from Noctua, DeepCool and Scythe.
https://old.reddit.com/r/Amd/comments/jsy8bw/robert_hallocks_response_to_all_zen_3_thermal/
https://www.pcgamer.com/amd-views-ryzen-5000-cpu-temperatures-up-to-95c-as-typical-and-by-design/
After 10 minutes of looping Cinebench R23 mulitcore, i settle into 83c, but i'm also maintaining 4.7GHz across all cores the whole time with an EK 360 AIO and some Curve Optimizer tweaks.
