changing from air cooling to liquid cooling
Solved by LIGISTX,
1 minute ago, tunde said:so i recently bought a prebuilt with air cooling i was wandering if it was possible to change the cooling to water cooling
here is the link where i got my pc
HP Omen 30L Gaming PC (Intel Core i7-11700F/1TB SSD/16GB RAM/RTX 3070) | Best Buy Canada
Can you put a 240 rad across the top? I can't tell if the top has fan mounting locations...
If it has 2 120 fan locations, likely it would fit. BUT, looking at pix online all I see are single 120 AIO's mounted to the top. A good air cooler will do a lot better than a 120 AIO will, so I would go with a nice air cooler in this situation.
