Buy the best GPU you can afford. It would be ridiculous to hold back for the sake of a CPU you're going to replace soon anyway. As another poster already said, a "bottleneck" (and I hate this term because there is always a "bottleneck" in any system) does not damage the PC or any component in it, it's just a limiting factor on performance.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1418978-help/#findComment-15296756
yep… but the bottlneck will be quite severe…  i mean it did throttle my old 1060 a lot, even a 1050ti was a "bit much" but its fine for a lot of games (and not fine for even more games, if you care about 60fps at all)
overall  it will still be an improvement over igpu.
5 hours ago, MoonMaroon said:
It should
keep in mind despite being heavily hyped at the time this cpu is really weak, 4c no mt, its ok, but a lot of games will have issues.
-Scott Manley, 2021
https://linustechtips.com/topic/1418978-help/#findComment-15297235
18 hours ago, MoonMaroon said:
It should! You'd likely only squeeze a bit more GPU performance out of it though depending on what you use it for if you upgrade to a Ryzen 3000 or 5000 chip.
I only play tomb raider and apex so I want it to carry through untill summer
https://linustechtips.com/topic/1418978-help/#findComment-15297938
  • 2 weeks later...
You can't. It's part of the CPU.
You can run the 1660 with the 2200g no problem though.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1418978-help/#findComment-15310946
-> Moved to Graphics Cards
You don't need to, it's automatic.
F@H
GPD Win 2
https://linustechtips.com/topic/1418978-help/#findComment-15310947
The case is. I have a ryzen 32200G. My graphics card will arrive on monday. What will be the order of things. Will I have to dissable the igpu first and then install nvidia drivers for the gpu or the card must be already in so the system can have a display input.
https://linustechtips.com/topic/1418978-help/#findComment-15311191
Merged into existing thread.
Put card in, install drivers. That's it.
F@H
GPD Win 2
https://linustechtips.com/topic/1418978-help/#findComment-15311199
Why do you want to disable the iGPU? If you're using the GPU instead you aren't going to get more performance by disabling it. Not enough to be notable at least. Leaving the iGPU enabled will help with troubleshooting later on if the graphics card starts to have issues as well.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1418978-help/#findComment-15311217
