Old Imac Hard Drive
Gabin
hi vi have a old imac and i am working on a new pc i was think of using my old hard drive from my mac in my curent device and then using the m.2 i have in the rig im building
or havein the mac hardrive in the new system im building algon with the ssd
wich is possible?
and wich is better?
I don't understand what it is you're asking, but if you're wondering if you can use the hard drive from your iMac in your new PC then that depends on the age of the iMac.
Phobos: AMD Ryzen 7 2700, 16GB 3000MHz DDR4, ASRock B450 Steel Legend, 8GB Nvidia GeForce RTX 2070, 2GB Nvidia GeForce GT 1030, 1TB Samsung SSD 980, 450W Corsair CXM, Corsair Carbide 175R, Windows 10 Pro
Polaris: Intel Xeon E5-2697 v2, 32GB 1600MHz DDR3, ASRock X79 Extreme6, 12GB Nvidia GeForce RTX 3080, 6GB Nvidia GeForce GTX 1660 Ti, 1TB Crucial MX500, 750W Corsair RM750, Antec SX635, Windows 10 Pro
Pluto: Intel Core i7-2600, 32GB 1600MHz DDR3, ASUS P8Z68-V, 4GB XFX AMD Radeon RX 570, 8GB ASUS AMD Radeon RX 570, 1TB Samsung 860 EVO, 3TB Seagate BarraCuda, 750W EVGA BQ, Fractal Design Focus G, Windows 10 Pro for Workstations
York (NAS): Intel Core i5-2400, 16GB 1600MHz DDR3, HP Compaq OEM, 240GB Kingston V300 (boot), 3x2TB Seagate BarraCuda, 320W HP PSU, HP Compaq 6200 Pro, TrueNAS CORE (12.0)
I am guessing you intend to format the iMac hard drive and blow away the data and OS. You'll need to repartition, as HFS isn't gonna play nice with Windows. If you do mean a magnetic media spinning hard disk drive, and not an SSD in the form factor of a SATA hard drive, I also hope your iMac isn't so old that it has a SCSI HD in it. Not many systems other than servers and Macs used SCSI natively, and finding an expansion card to support one may not be easy, and being bootable is another gamble.
No iMac has ever used SCSI drives - they've all been IDE (G3, G4) or SATA (G5, all Intel).
i want to use Mac os and Windows so could it work? if my ssd and hdd where in the same sysmtem and i just change the boot device evrytime i want to change?
and could it run the latest macos update?
No, you can't run Mac os on your pc. (I understand that hackintosh is a thing, but given the op's tech level, I don't see this as a valid option)
That's not how you go about running macOS on a PC. You can't just pull a drive from a Mac and boot from it in most cases.
Technically it is actually possible with a native macOS installation (I'm not talking about a Hackintosh), but in 99.9% of cases it won't work.
Excuse my ignorance, but what's the difference between hackintosh and native install on non apple hardware?
A Hackintosh uses some form of bootloader (Clover back in the day, OpenCore these days) to inject kexts (drivers) into the boot process. What I referred to as a native install is what you'd find on a proper Mac - macOS installed directly on the hard drive. It is technically possible for a native installation to boot without the use of a 3rd party bootloader on a non-Apple PC, but it's incredibly unlikely for that to work.
