Can't package my game unreal engine 5
Solved by Linus No Beard,
6 hours ago, AndreiArgeanu said:I mean it tells you where the file is. It might be worth taking a look over even if its c# it's not that difficult to understand since only that single cs file seems to cause the issue.
i found the problem when i renamed my project i included a space in the name that broke the code
Featured Topics
3
CorruptVenom ·
Posted in New Builds and Planning4 -
1
Justbon321 ·
Posted in Troubleshooting2 -
8
Ozzieh_man ·
Posted in Troubleshooting0 -
aqarwaen29 ·
2
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
