How do I connect an Ethernet and a Wi-Fi connection to a windows laptop and use them both?
Solved by tkitch,
Correct.
For example, if you wanted to look, Peplink makes a hardware router solution that will balance across two pipes. But it ain't cheap.
aren332 ·
Harry_rn ·
Posted in Troubleshooting0 -
2
1
kim921 ·
Posted in Build Logs2 -
_y0sh ·
Posted in New Builds and Planning3 -
James Jonathim ·
Posted in Troubleshooting1 -
6
DoDoTheGoD ·
Posted in Graphics Cards4
