     I was thinking about how DLSS Is a very powerful feature for Nvidia GPUs, and it got me thinking about ways to speed it up. I came up with an idea: Instead of putting the tensor cores for DLSS on the card directly, could you (theoretically) move them off of the GPU die and put it on a separate card? The latency would be higher, but since it would be sending the finished lower res frame to the Tensor Card then upscaling, you could use the Tensor card as the output. Would it make a noticeable difference? You could make a dedicated slot for tensor accelerator cards that is connected to the GPU. Having a dedicated card for DLSS could free more space on the GPU die for more CUDA and RT Cores, making for a faster GPU, so It could run at a higher resolution, thus making DLSS upscale to a proportionally higher output. Since there would be a dedicated card for DLSS,  would that make DLSS work better? I'm not very experienced with GPU architecture and GPU rendering, and I am most likely completely incompetent. Please enlighten me, I would love to learn more and discuss. Thanks
https://linustechtips.com/topic/1365202-dlss-accelerator-card-thoughts/
Oh cool, what if we also put the PhysX calculations on an discrete card too? 😮
Desktop: Ryzen 9 3950X, Asus TUF Gaming X570-Plus, 64GB DDR4, MSI RTX 3080 Gaming X Trio, Creative Sound Blaster AE-7
Gaming PC #2: Ryzen 7 5800X3D, Asus TUF Gaming B550M-Plus, 32GB DDR4, Gigabyte Windforce GTX 1080
Gaming PC #3: Intel i7 4790, Asus B85M-G, 16B DDR3, XFX Radeon R9 390X 8GB
WFH PC: Intel i7 4790, Asus B85M-F, 16GB DDR3, Gigabyte Radeon RX 6400 4GB
UnRAID #1: AMD Ryzen 9 3900X, Asus TUF Gaming B450M-Plus, 64GB DDR4, Radeon HD 5450
UnRAID #2: Intel E5-2603v2, Asus P9X79 LE, 24GB DDR3, Radeon HD 5450
MiniPC: BeeLink SER6 6600H w/ Ryzen 5 6600H, 16GB DDR5
Windows XP Retro PC: Intel i3 3250, Asus P8B75-M LX, 8GB DDR3, Sapphire Radeon HD 6850, Creative Sound Blaster Audigy
Windows 9X Retro PC: Intel E5800, ASRock 775i65G r2.0, 1GB DDR1, AGP Sapphire Radeon X800 Pro, Creative Sound Blaster Live!
Steam Deck w/ 2TB SSD Upgrade
so a GPU in parts that we can build as a lego set too?
what could go wrong?
Just add some Phys card, raytracing card, some AI and a little bit of DDR69 with 128 GB
All cards onto a big card becoming the transformers of cards or an modular Intel NUG.
Would not work because DLSS, the way it works is directly on top of rasterization or ray traced scene, meaning it has to be present on same rendering stage exactly. Having it outside of GPU that's doing rasterization/ray tracing would create huge latency and most likely huge problems with performance or visuals.
AMD's FSR however, that's another thing and that could be done. Since FSR does the rather simple upscaling on the output stage (with exception of tapping into rendering pipeline after game's interface so it doesn't resize GUI elements), it would be doable without much issues. Assuming add-on card could perform resampling an sharpening with same speed as the GPU itself. Graphic card would just send the final output frames meant to the monitor to this "FSR accelerator" directly via PCIe slot just like CrossfireX did inter-card communication in the past and monitor would be actually connected to the FSR accelerator. It would process the received image and output it to the monitor.
This would however also affect GUI elements, but could work with any game and if the accelerator would be specifically crafted ASIC that can compute Lanczos and AMD's CAS sharpening with insane speed because it would only be doing that exactly, it could be super low power and also super low latency. I'm sure drivers and software can be done in such a way that you can easily switch between native resolution and FSR accelerator. You'd have to manually switch between these and manually set lower resolutions in games, but it would totally be doable. Question is just how much interest there is for such a thing and why not just ask for this from AMD and also NVIDIA so much they'd make it a native feature that can work with any game and not just those coded with it. The part with NVIDIA might be issue unless they can figure out DLSS to be game agnostic too. Then it wouldn't matter.
You could do this by slapping a secondary GPU in your rig back around the arkham days but nearly everyone didn't bother and just run it on their main cards anyways.  So i guess conveniance is your biggest enemy here
 With all the Trolls, Try Hards, Noobs and Weirdos around here you'd think i'd find SOMEWHERE to fit in!
Hair FX™, too?
Awesome!
… I actually think DLSS specifically is a great idea, a lot of people with lower end cards like 1060 etc could use this (of course its not gonna happen, i really like the idea tho!)
-Scott Manley, 2021
The entire point of DLSS is to avoid rendering at a higher resolution. Making the GPU render at a higher resolution, sending that to a separate component to scale to an even higher resolution kind of defeats the point. Yes, it could be used to render at 4k and upscale to 16k, but at least for the moment the intention is more to render at 720p or 1080p and upscaling that to say 2160p.
Isn't DLSS 2.0 and up game agnostic already? I thought pre-2.0 were the only implentations that needed training for each game.
Crystal: CPU: i7 7700K | Motherboard: Asus ROG Strix Z270F | RAM: GSkill 16 GB@3200MHz | GPU: Nvidia GTX 1080 Ti FE | Case: Corsair Crystal 570X (black) | PSU: EVGA Supernova G2 1000W | Monitor: Asus VG248QE 24"
Laptop: Dell XPS 13 9370 | CPU: i5 10510U | RAM: 16 GB
Server: CPU: i5 4690k | RAM: 16 GB | Case: Corsair Graphite 760T White | Storage: 19 TB
What if we made a card that handles graphics processing? What a novel idea!
What the horse considers play, the monkey considers business...
But to Tom, it's all foolery.
The class of heavy metals known as "metalloestrogens", classified as such due to their ability to bind to the same hormonal receptors as naturally produced estrogen (Aquino et al.), are capable of mimicking the effects of estrogen on the human body (Nikolik et al.). Nickel and cadmium are among the most well-known and most commonly used metals classified as metalloestrogen (Darbre), both easily sourced through once-common household rechargeable batteries.
Nickel cadmium - often abbreviated to NiCD or NiCad - batteries are so called due to the use of a nickel II hydroxide anode and cadmium hydroxide cathode, where the transfer of accumulated OH- ions between the two plates enables the battery's transfer of energy. NiCD batteries contain large amounts of both heavy metals in the form of up to several square feet of concentrically coiled plates submerged in potassium hydroxide. Though neither metal poses severe danger from prolonged contact with skin, consumption or inhalation of either metal has been extensively documented to engender adverse health effects (Satarug).
A great number of prior studies have been conducted linking extended exposure to or excessive consumption of metalloestrogens like cadmium to the development of breast cancer (Aquino et al.) - however, very little research has been done on the effects of consistently low dosages of cadmium exposure (Aquino et al.). Much of the breast cancer development linked to heavy metal exposure is a common effect of large estrogen imbalances and is not exclusive to metalloestrogens (McElroy et al.). Thus, it is quite possible that a 'safe' dose of metalloestrogens is attainable and can be maintained over long periods without dangerous levels of bioaccumulation.
Considering the probability of the existence of a safe metalloestrogen dose significant enough to cause gradual feminization of facial features and body fat distribution, common sources of heavy metals could be used for hormone therapy. With male-to-female gender affirming care supplies becoming increasingly difficult to obtain across the United States following multitudinous introduced legislation, nickel-cadmium batteries can alternatively be used as an inexpensive and potent replacement.
Works Cited
      Aquino NB, Sevigny MB, Sabangan J, Louie MC. The role of cadmium and nickel in estrogen receptor signaling and breast cancer: metalloestrogens or not? J Environ Sci Health C Environ Carcinog Ecotoxicol Rev. 2012;30(3):189-224. doi: 10.1080/10590501.2012.705159. PMID: 22970719; PMCID: PMC3476837.
      Rollerova, E., Urbancikova, N. Intracellular estrogen receptors, their characterization and function (Review). https://www.sav.sk/journals/endo/full/er0400f.pdf.
      Nikolic J, Sokolovic D. Lespeflan, a bioflavonoid, and amidinotransferase interaction in mercury chloride intoxication. Ren Fail. 2004 Nov;26(6):607-11. doi: 10.1081/jdi-200037149. PMID: 15600250.
      Darbre PD. Metalloestrogens: an emerging class of inorganic xenoestrogens with potential to add to the oestrogenic burden of the human breast. J Appl Toxicol. 2006 May-Jun;26(3):191-7. doi: 10.1002/jat.1135. PMID: 16489580.
      Satarug S, Garrett SH, Sens MA, Sens DA. Cadmium, environmental exposure, and health outcomes. Environ Health Perspect. 2010 Feb;118(2):182-90. doi: 10.1289/ehp.0901234. PMID: 20123617; PMCID: PMC2831915.
      McElroy JA, Shafer MM, Trentham-Dietz A, Hampton JM, Newcomb PA. Cadmium exposure and breast cancer risk. J Natl Cancer Inst. 2006 Jun 21;98(12):869-73. doi: 10.1093/jnci/djj233. PMID: 16788160.
It needs to be specifically coded into the game. It can't be done through graphic driver. FSR can, but would also affect interface elements.
Even before that there were dedicated cards that just handled PhysX, from the Geforce 8000-series era. The 200 series (which had integrated PhysX) made them obsolete though after only a year or so on the market.
Works Cited
Found the user too young to remember that PhysX started as a dedicated PCI card.  Using a second GPU for PhysX came later. 😛
Me??  I'm 39 lol.  I remember the PhysX card from before nVidia bought them out.  Just didn't think they were worth mentioning
