my sis is currently doing her phd she has the option for google cloud machine learning or geting a gpu (she would probly have to pay for the gpu) so i found a tesla m2075 6gb (you barly find anything on the internet about it) for 50 bucks and i also found a 1060 6gb but it has a clock of 139MHz (a sensor is broken) what do yall susgest?
|:Insert something funny:|
https://linustechtips.com/topic/1364045-what-to-pick-for-machine-learning/
Id go for the cloud gpu option. Whats the disadvantage to this option?
That tesla seems like fermi, and those are well out of support now and most programs won't work with them now.
THe 1060 seems a bit too limited.
Do they suggest gpus? If you don't care about speed, you can normally do it all on cpu.
16 minutes ago, adarw said:
a sensor is broken
I doubt that. There are barely any sensors on that card that cause it to throttle to those speeds. That card is 100% messed with (shitty shunt mod attempt is what I have in mind) or damaged gpu core wise.
i guess the cloud thing might be the best, would a 1060 with normal clock be ok to use aswell? im going to buy one for myself soon.
oh lol i just saw the post and i guess he did try and mod it lol https://www.kijiji.ca/v-desktop-computers/ottawa/defective-pny-gtx-1060-6gb-gpu-accepting-offers/1579469063
Reaally depends on the uses, but most programs shoudl at least work.
GTX 1060 should be "okay" but as said before it depends on the usage, the most important aspect is the VRAM, a lot of midrange GPUs even from that era are fast enough for machine learning, but if the model doesn't fit in the VRAM then it's useless and there's no workaround for that, unless you train on the CPU which is much slower
Don't use any of the AMD cards as their support is severely lacking for machine learning
a GTX 1070 with its 8GB of VRAM is also a decent choice, if you can find one for a decent price
Quote or Tag people so they know that you've replied.
ive found a 1080 for 400 cad is that reasonable?
Hmm, it would've been 2 years ago, but considering the GPU shortages I think that sounds alright?
To put it in perspective the GTX 1080 is around the performance of a regular RTX 2060 which costs around the same when new
Why not both? Use the 1060 for small, local tests and then the cloud ML (is it an actual compute instance, or just one of their managed services?) for heavy processing.
That tesla isn't that useful.
Even a 1050 would be okay for small scale stuff, and 10x faster than using a CPU already.
One can always workaround that by reducing batch sizes, using fp16 weights and other stuff, since she's doing a PhD one can assume she can try to get around those limitations.
By "severely lacking" you mean non-existent, right? 😆
Given that the 2060 has tensorcores, if one can make use of half-precision the 2060 ends up being almost twice as fast as the 1080.
FX6300 @ 4.2GHz | Gigabyte GA-78LMT-USB3 R2 | Hyper 212x | 3x 8GB + 1x 4GB @ 1600MHz | Gigabyte 2060 Super | Corsair CX650M | LG 43UK6520PSA
ASUS X550LN | i5 4210u | 12GB
Lenovo N23 Yoga
cleard up a lot thanks 🙂 I guess i will do that, why does amd not support machine learning? dont they have more vram?
They do have more vram and nice hardware (although their consumer platform lacks the equivalent of tensorcores, only their instinct cards have that), but they software support is non-existent.
All of the big ML frameworks and tools usually rely on CUDA. AMD has a "compatibility software" (in reality it's a fully fledged compute stack) called ROCm, which Pytorch does support officially, but it has no support for Navi GPUs, and even getting it to run in older Vega and Polaris GPUs is not that straightforward, and performance is really disappointing (a Radeon VII performs about the same as my 2060Super).
There's also DirectML on Windows, but doing ML on windows is a pain and performance is WORSE than using a CPU.
Lenovo N23 Yoga
I just meant in the sense that you run out of VRAM beyond those optimizations, there's no way around increasing or substituting your VRAM, even though the GTX 10 Series suffers from terrible FP16 performance, but otherwise it's a good point
