24 pin power connector question
Fedor
Hello! so ive been buying pc parts for my first pc build, i recently bought the power supply (EVGA 750w 80+ gold) and i noticed that one of the holes on the 24 pin power connectors is empty. is this supposed to be like this? my motherboard is a z490 a pro if that matters.39BE9CC5-5587-4BFB-8B21-34A4A703F6F5.thumb.jpeg.32369d8442256844013d274711f34399.jpeg
Yea, that’s normal 🙂
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
thank you!!! i was worried i was going to need to buy another power supply
It's normal. The missing pin was formerly used for -5V but that hasn't been used for 20 years, power supplies no longer have -5V power so the pin is left empty. I'd be more worried if it wasn't empty.
Moved to the power supply forum.
Appreciate it!
