You have 'collectSound.play();", but the correct line is "collectSound.Play();"
Notice the capital P in "Play" in the correct line.
These are super small errors and anyone doing any sort of coding is bound to make them, so can't blame you 😄
So always be sure to double-check with these sorts of functions to see if they should be a capital letter or not.
https://linustechtips.com/topic/1354032-unity-coin-sound-help/#findComment-14853828
haha, thanks i appreciate it. i am pretty new and realised capital letters are a problem 😄
one thing please, lets say i have no script or anything.
lets say i have a car, and when it passes a point it makes a sound. how can i do that?
i attached a image, i made a object - attatched audio - and box collider set to trigger. my car just passes through it
https://linustechtips.com/topic/1354032-unity-coin-sound-help/#findComment-14854453
As far as I know, you can only do something with a collider in a script, to within the OnTrigger function.
You would need to make sure it only once makes a sound for colliding through that, because otherwise you could just stand still within that collider and it would go make that sound over and over.
https://linustechtips.com/topic/1354032-unity-coin-sound-help/#findComment-14854789
this is another topic.
my car drives perfectly, but the issue is it doenst drive in a straight line. if i just accelerate, it sloowly turns right over a medium distance.  how can i stop this
https://linustechtips.com/topic/1354032-unity-coin-sound-help/#findComment-14857106
Without any additional info on what your project is all about, this is not possible to answer.
I can point you to what you should take a look at:
1. The origin of the car. Check this picture out:
The cube is set at an angle, compared to the empty gameobject it is in. If I say to the gameobject "go forward", that is not one of the faces of the cube, but rather one of the diagonals, because it's are rotated.
Of course this is a simple example, with a larger model the issue can be exaggeration. Check if everything in the object sees 'forward' as the same time.
2. Your code may apply some forward and also sideways movement. That depends on the script you use.
3. Your car may just not have total grip on the road, go in the air and pick up some sideway momentum.
What exactly is the issue is difficult to say, but these are some pointers on what to look out for.
https://linustechtips.com/topic/1354032-unity-coin-sound-help/#findComment-14857593
