Does using a custom fan curve damage the fans ?
M1800
I have a NVIDIA rtx 2080ti and set a custom curve to get approx 60C at 100% usage, it's not very exaggerated, but will it damage my fans at long-term?
No, it’ll be fine.
Better question is, why do that? PC parts don’t mind running a bit warm, and maxing fans out just makes then loud… you can just let the GPU manage it’s fan on auto, it’ll be fine 🙂
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
No reason to, it will wear out the fans faster if they are spinning more, and it will be louder. As @LIGISTXsaid.
Not that active so I may not respond.
Fans are rated to run at their maximum RPM 24/7, that's how they measure their longevity.
You'd have no issue running them at an increased speed.
You wouldn't start to see a noticeable/problematic degradation in the fans until the card is long past obsolete anyways.
ALTHOUGH, you may be better off setting a fixed RPM. Sudden ramping up and stopping wears out a fan faster than just letting it run 24/7.
Fans changing RPM is also far more noticeable than a fan sitting at fixed speed and noise-level.
[Main Desktop]
CPU: AMD Ryzen 5 5600X  GPU: EVGA RTX 3070 Ti (FTW3 Ultra)  MOBO: MSI Gaming Pro Carbon (X470)  RAM: G.SKILL Ripjaws V DDR4-3600 CL16 (2x8GB)
COOLER: Arctic LiquidFreezer II 280 STORAGE: G.SKILL Phoenix FTL 240GB SSD, Crucial MX500 1TB SSD, Toshiba 2TB HDD, Seagate 4TB HDD
PSU: EVGA GQ-1000W 80+ Gold  CASE: The MESHMOD v1.0 (Custom Deepcool Matrexx 70 chassis)  MONITOR: AOC 24G2 144Hz (IPS)
MOUSE: Logitech G502 HERO (wired)  KEYBOARD: Rosewill K81 RGB (Kailh Brown)  HEADPHONES: HiFiMan Ananda, Drop x Sennheiser HD6XX
IEMS: 7Hz Timeless, Tin Audio T2, Blon BL-03, Samsung/AKG Galaxy Buds Pro  STUDIO MONITORS: Mackie MR524, Mackie MRS10  MIC: NEAT Worker Bee
INTERFACE: Focusrite Scarlett Solo  AMPLIFIER: SMSL SP200 THX AAA-888, XDUOO XD-05 Basic  DAC: SMSL Sanskrit 10th MKII (upgraded AK4493 Version)
WHEEL: Logitech G29 + Logitech G Shifter
[Stream Encoder]
CPU: AMD FX-9590  GPU: Sapphire R9 390X (Tri-X OC)  MOBO: ASUS Sabertooth R2.0 (AM3+)  RAM: G.SKILL Ripjaws X DDR3-1866 (2x8GB)
COOLER: EVGA CLC 280 PSU: MSI A750GF 80+ Gold CASE: Phanteks P400A Digital
[Garage]
CAR: 2003 Honda Civic Coupe LX (EM2)  ENGINE: D17A1, planned K20A2 swap  INTAKE: DIY Solutions Short RAM  HEADERS: Motor1 4-2-1 with Cat-Delete
EXHAUST: Yonaka 2.5" Cat-Back with 3.5" tip (YMCB-CIV0105)  COILOVERS: MaXpeedingrods adjustable  RIMS: Core Racing Concept Seven Alloys (15x6.5)
RECEIVER: Kenwood DPX304MBT  SOUND DEADENING: Damplifier Pro Deadening Mats  SOUND DAMPENING: Custom solution, layers of thick insulation
DOOR SPEAKERS: Kenwood KFC-P710PS 6.5" Components  WINDOW LEDGE SPEAKERS: Kenwood KFC-6996PS 6x9" 5-Ways
