building keyboard help!
Solved by Deuxez,
5 minutes ago, Jakob.D said:Why can't you buy a pre-built?
It's often cheaper
Yeah its ALOT cheaper almost all of the time, but is because some have either bad build quality, bad switches etc. I doubt you will get any better quality from a £150 custom keyboard than a £100 prebuilt keyboard. So @memz, just look for a prebuilt keyboard with all the features you want on it. You can still mod a prebuilt keyboard with O-rings, custom keycaps or lube(need to be hotswappable) if thats what you are after.
Got myself a blitzwolf KB1 with O-rings, that legit only set me back by like £60. It looks great, sounds OK (need better stabilizers), and feels OK too (worn out brown switches, id like red switches instead).
