PSU Making spark noises and i saw one
3 minutes ago, PrevenX said:Hello,
A few minutes ago I started hearing weird noise coming from the back of the PSU. When I launched a game I even saw a spark inside it?! Can it be dust? or is the PSU Daying? It only occurs when under load.
Have a Video of the sound if somebody wants.
PC spec.:
I5-8600k overclocked 5Ghz AIO
Zotac AMP! Geforce 1080
MB: ASUS strix Z370H
PSU Corsair RM650X
Seagate 1TB
Crucial 250Mb SSD SATA
Old 3yearsThank you
Your OC'ed CPU and the video card would push that 650 W PSU close to the limit. Running a PSU long term at max load can cause internal failures. Sparks come from a number of reasons but if you sea one, that's probably an arc, meaning you have unshielded connections somewhere. I would replace that unit asap with a higher wattage one.
750 or better 850 W for your setup. You can also try to run the cpu at base clocks but I would strongly advise against powering on that pc at all. If the PSU goes, there is good chance it will take your graphics card and drives with it, as they have less fault tolerances than the motherboard. Worst case would be an electrical fire that could destroy your entire home. Dont' mess with power. The fact that your pc is still running is a good sign, just don't try your luck with it.
