Fans & AIO Rad Question
WiteNite
I am going to be buying an Arctic Liquid Freezer II 360 tomorrow, and I was wondering, if I buy some RGB fans that have a higher CFM and higher static presure, would that allow it to run slower/quieter than the stock fans? Would it really make a differance?
so the CFM and static pressure aren't an accurate measurement. Why you ask? Glad you asked!! All manufactures have there own testing methods and its not standardized across the industry. Also, the numbers printed, are when the fans are at 100% speed.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
It is more so, I am wanting the RGB fans to match the rest of the set up. I was looking at RGB ones that are the same ish specs... then I looked down the filter list and thought, why not go stronger...
what RGB fans are you looking at getting?
"Black Out"
10 hours ago, WiteNite said:
I think it was these fans that I was looking at, it has been a few weeks...
https://www.memoryexpress.com/Products/MX00114165
InWinSaturn ASN120 120mm ARGB Case Fans Kit, 3x 120mm, Triple Pack
I really don't think those fans have the static pressure that they say they have simple based on the fan design. all other fans with similar fan design have about half the static pressure.
the really question is, does it really matter?
probably not. aio use thin rads that are not very dense. so it will not be the best in class but it will work.
tbh 99% of rgb fans focus on the rgb and not the fan. so options for killer fans with rgb are limited.
I'd suggest maybe some ek fans.
