A 5-1 PWM splitter shorted and broke. (Hope I Am Right)
Elite Knight
 (Hope I Am Right)
I know, I know I got a 5 in 1 4pin pwm plug and it shorted the centre pwm connector since when I plug into it my rgb fan flickers and refunses to spin so I unplugged a cpu fan (got 2) and wait for my new mobo
This is what I got :S I know
https://www.ebay.com.au/itm/1-2-3-4-5-6PCS-5-Way-PWM-Splitter-Hub-4pin-CPU-Computer-Fan-Black-Sleeved/124283603717?ssPageName=STRK%3AMEBIDX%3AIT&var=425149443241&_trksid=p2060353.m2749.l2648
Everything running fine just that one plug is dead so yea I am in idiot.
| - MSI Gaming X RTX3060ti 8GB ( HDMI x 1 ) - ( DP x 3 ) - |
| - 16GB Kingston Hyper Fury X DDr4 2400Mhz - OC to 3200mhz XMP Profile 1 Enabled - |
| - i5 - 10400f 6 core 12 threads 2.9Ghz Stock - 4.3Ghz Boost - |
| - MSI Z590 Pro WIFI 6E Motherboard LGA 1200 - |
| - 500GB NVME Samsung 980 Pro - |
| - WD Blue 4TB HDD 7200Rpm - |
| - Lenovo 27 Inch 75Hz Monitor D27 - 20B (HDMI) - |
| - Thermaltake Tough Power GX1 RGB 700W 80+ Gold PSU - |
| - Logitech G903 Wired/Wireless Micro USB - |
| - Logitech K120 Basic Keyboard - |
| - Razer Desk Pad - LTT Northern Lights Mouse Pad (600x300) - |
| - Intel l225-V 2.5Gbit Onboard NIC
| - Intel® Wi-Fi 6E AX210 2.4GHz/5GHz/6GHz - |
| - Intel Bluetooth 5.2 - |
| - Internet Speeds - Download - (Download Average = 800Mbit) - |
| - Internet Speeds - Upload - (Upload Average = 40Mbit) - |
12 minutes ago, Elite Knight said:
 (Hope I Am Right)
I bought a similar on on amazon that still works great. Looks just like it but connects directly to the power supply. You could have an issue if you plug to many fans to the motherboard. If one fan is not working, I would not use the adapter, there are no wires, it's all traces on the pcb. Chances are that another one will fail or short out a fan or worst case, cause a fire if shorted to ground (see NZXT H1 Fire).
I did my new board has right amount of ports and everything besides that pwm connctor works fine so yea I will wait and get a splitter not that board ones that cpu coolers somtimes have.
How many and what fans did you connect? Its more than likely you went over the 1A limit.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
5 which is should be able to. it has 5
