help me pls theres smth wrong
so basically you know how on amd motherboards, theres brackets you need to take off to put on your cooler. well, the screws keeping those brackets in. refuse to come out, and i have a magnetic screwdriver and stuff it just wont come out. help pls
What motherboard, CPU, etc.? Helps to include this so other can google an image to better assist.
Are you talking about the screws on the AMD CPU cooler? They might be captive screws which is why they will completely unscrew but not come completely off. I would make sure all 4 screws are completely unscrewed and then just lift the cooler off the mobo.
its this motherboard and i have a amd ryzen 5 3600 my cooler is id cooling se-234-argb, the screws im talking about it the ones next to where u put the cpu, yk like the black brackets you need to take off in order to put in ur cooler??
You should be able to unscrew those 4 silver screws around the socket and the brackets come off.
This may help?
This guy shows more of removing the brackets on an AMD motherboard
This may help?
???? i know how to unscrew things it just wont come out ://
Well, unless you wanna give up more information, there's not much else anyone on a forum's gonna be able to do to help you.
information like what ?
Geeze man, put some muscle into it. If the screw driver bit fits properly, it's just the forearm needs to work out more.
Try harder.
Try harder.
ouch, i did and it does fit properly. ;--;
Need a proper bit. Don't want to mess them up.
They are tight. They break free all at once. Then turn easily out.
okay well thanks ill just ask my grandpa to do it -----
This whole time @ShrimpBrimewas talking smack to an 11 year old
Before you reply to my post, REFRESH. 99.99% chance I edited my post.
My System: i7-13700KF // Corsair iCUE H150i Elite Capellix // MSI MPG Z690 Edge Wifi // 32GB DDR5 G. SKILL RIPJAWS S5 6000 CL32 // Nvidia RTX 4070 Super FE // Corsair 5000D Airflow // Corsair SP120 RGB Pro x7 // Seasonic Focus Plus Gold 850w //1TB ADATA XPG SX8200 Pro/1TB Teamgroup MP33/2TB Seagate 7200RPM Hard Drive // Displays: LG Ultragear 32GP83B x2 // Royal Kludge RK100 // Logitech G Pro X Superlight // Sennheiser DROP PC38x
2 minutes ago, watacukrowa said:
14..
I'm sorry, was just throwing shade at my friend there lol.
I know sometimes it feels like you might break something, and that apprehension sucks.
Watch the videos again and make sure your bit fits well, it makes a difference for sure.
okay thanks im just trying to be careful not to short or break the motherboard since its my first build yeah im gonna have my grandpa try it this weekend
No I told the 11 year old.... or perhaps a 30 year old that may read this thread...... nothing more than.... the truth.
For you, it was just sarcasm, because you already knew the answer.
8 minutes ago, watacukrowa said:
update:::: i fucking did it lol and im 14
Congrats sir
Enjoy your new system 🙂
11 hours ago, Mister Woof said:
Congrats sir
uhhhhhhhhh well so like everything turned on.. my monitor wont ;-----;
Full specs please
And did you plug the monitor into the motherboard or the GPU?
3 minutes ago, Mister Woof said:
Full specs please
i plugged it into the gpu and my specs are
mobo:tuf gaming b450m  micro atx
cpu: ryzen 5 3600
cpu cooler: se 234 argb id cooling
ram: crucial ballsticks 2x8
case: coolermaster mb520 argb mid atx
storage: 4tb seagate hdd
power supply: thermaltake smart pro 650w
monitor:dell s2419hgf 24in `144hz 1920 x 1080
Do you know if your motherboard box has a sticker for "ryzen 3000 ready" on it?
2 minutes ago, Mister Woof said:
Do you know if your motherboard has a sticker for "ryzen 3000 ready" on it?
yep it does lmao
kinda just wondering if i need a dp or dvi cables for my gpu ??
What GPU is it?
