help me pls theres smth wrong
6 minutes ago, watacukrowa said:
gtx 1650
make sure your monitor has selected the appropriate input (DVI, HDMI, DP, etc)
Before you reply to my post, REFRESH. 99.99% chance I edited my post.
My System: i7-13700KF // Corsair iCUE H150i Elite Capellix // MSI MPG Z690 Edge Wifi // 32GB DDR5 G. SKILL RIPJAWS S5 6000 CL32 // Nvidia RTX 4070 Super FE // Corsair 5000D Airflow // Corsair SP120 RGB Pro x7 // Seasonic Focus Plus Gold 850w //1TB ADATA XPG SX8200 Pro/1TB Teamgroup MP33/2TB Seagate 7200RPM Hard Drive // Displays: LG Ultragear 32GP83B x2 // Royal Kludge RK100 // Logitech G Pro X Superlight // Sennheiser DROP PC38x
im not sure whatr ur saying but it came with a hdmi
the monitor usually will be able to automatically detect which input is in, but there is a button there somewhere on the monitor that lets you select which input. make sure its selected the appropriate one
well i wont know which one is selected cause it wont turn on
the monitor should allow you to do this regardless if there is any input.
I am presuming your monitor itself is powering on?
you plugged the monitor power cable into a power source, right?
yes the power cable is plugged into the wall and the monitor and and the hdmi is in the monitor and gpu, and no the monitor isnt turning on at all
The LED indicator on the monitor isn't turning on?
Are you sure the wall outlet you're plugged into is not tied to a light switch?
yes im sure because i use it for other things too
Then if the monitor power indicator isn't on, I would presume something is wrong with the monitor. Try a different display. Even a TV.
Also make sure you shoved the power cord into the display fully. They can sometimes be a bit tight.
okay thank u ill try it right now
I'd recommend a surge protector as well instead of just plugging into the wall
yea i have one also i plugged it into the tv and nothing happened so now im assuming i did something wrong in the pc;---;
did you select the right input for the TV?
yep
yep
Just to be clear, the TV turned on still but did not detect signal, is that correct?
I'd go back into your PC and reseat everything. CPU, memory, GPU....make sure everything's plugged in appropriately. Any PCIE supplemental GPU cables (probably not for a 1650 but check). Make sure the top EPS power plug for your CPU is plugged in as well.
yeah i have all that plugged in but also my ram isnt lighting up and ive checked my chords a bunch of times
Can you take a photo of the interior of your case so we can see what everything looks like?
here---- sorry not sure if it helps
IMG_20210225_095016.thumb.jpg.a4a3006e69840502f84dd2dcf1acadec.jpgIMG_20210225_095027.thumb.jpg.526ad3149931a6ff6285a02863ee367c.jpgIMG_20210225_095039.thumb.jpg.3b42a9fc55eaab7808df8758af9588e6.jpg
is the EPS plugged in?
Are the GPU fans spinning?
Is there any input (black screen, etc.) or just no signal?
Do you have a different GPU to try out?
I'd give re-seating everything a shot. Even just giving the ram an extra firm seating. Sometimes RAM not plugged in all the way can make things go bonkers.
According to the ASUS website (which is being slow as heck today for some reason) it should support the 3600 since BIOS 1806. I don't know which one you have on the board, but I have to assume if it says Ryzen 3000 ready it is loaded with the correct BIOS. It does not appear this board has BIOS Flashback, so we can't be sure unless you have a 1st or 2nd gen chip laying around to find out if that may be the cause.
i dont have a different gpu to try out, yes the gpu fans are spinning.
and no the screen doesnt turn on at all when i click the power button it just stays as if nothing was plugged on and ill give the ram another try after class
uh how do i know if i have 1st or 2nd gen chip
