Will one of those acoustic shields block sound from leaving too?
Solved by Psittac,
Yeah I was thinking along the lines of what @Blue4130 said, they are for damping reverb and echo. I know little about acoustics but hear it mentioned in my normal searching and that was my understanding.
I'm sure it will help but it won't be a solution.
One cost effective route is moving blankets, if you hang those up it might deaden some of the sound.
