need some helps with my case fans
5 minutes ago, dreamcast4599 said:@Noctua Fan Fan heres the links to the fans i use in case it helps you out with my issue i use 6 vardars for my rad and the rest of the case fans are for my case
https://www.newegg.com/cooler-master-r4-120r-20pc-r1-case-fan/p/1YF-0010-000K6
You just need one of these: https://www.amazon.co.uk/gp/slredirect/picassoRedirect.html/ref=pa_sp_atf_aps_sr_pg1_1?ie=UTF8&adId=A08546583ECL7DPYATRBH&url=%2FLeHang-Splitter-Magnetic-standoff-connector%2Fdp%2FB07RPPTCN7%2Fref%3Dsr_1_2_sspa%3Fdchild%3D1%26keywords%3D4%2Bpin%2Bpwm%2B4%26qid%3D1613099668%26sr%3D8-2-spons%26psc%3D1&qualifier=1613099668&id=1154896130596419&widgetName=sp_atf
Or if you plan to run them at different RPMs then get 3-4 x 4-pin versions and you'll be fine.
If you want to plug each one into the mobo, don't exceed 3 fans per header.
