Low fps in rust and csgo on a 3060ti
16 hours ago, BornOrca said:Great thanks, I actually didn’t know that and that really cleared things up for me, I’m gunna go to bed now cuz it’s late but I’ll definitely try that in the morning.
i probably will end up getting this bundle then if it’s decent. I’m just sick of getting fps drops in games like rust when loading in big monuments.
thanks so much for all your help so far guys, you’ve been great
Edit:
really sorry to bother you guys, I had one last question, is it worth upgrading my motherboard and cpu first to then waiting until I can afford better ram later, or upgrading my ram first?
You CAN use your current RAM with a new motherboard and CPU. New RAM will also help. Once again, I would suggest looking around at more reviews and benchmarks of a 3600 with different RAM speeds. That said, I've always had great luck with Corsair Vengeance. You can go a little cheaper, but it's not let me down on Intel or AMD.
https://www.amazon.com/Corsair-Vengeance-PC4-28800-Desktop-Memory/dp/B07RM39V5F
