How many Hz do i need?
Solved by flashiling,
since you posted this in displays subforum i imagine you're talking about monitors.
and this depends on your pc and the games you play and the resolution,
if you wanna play single player games only in 4k i think you could stick with a 60Hz, if you play 1440 i think you'd have to go lower in graphics since a 2060s won't reach 144fps on ultra in many games.
if you are a hardcore fps player and you play games like csgo/overwatch/R6S then go for a 144Hz 1080p monitor (maybe a 240Hz if you really want to, but it's not as big of a difference between 144 and 240 so it should only be if you really want to play top tier)
