Hi, I need help figuring out why Switch 3 is being printed no matter what. It does this properly for switch 1 and 2, but continues to print switch 3 as on, when it is off. Here is the picture of my code, sorry it’s not really legible...
EDIT: These are generic brand light switches from Walmart for $0.67 a piece, couldn’t resist. They work well too.
specs
ASRock B650I Lightning WiFi
AMD Ryzen 7 7700X
KLEVV CRAS V RGB (2x16GB) 6000MT/s out of the 7200MT/s I could be running
ASUS RTX 3060 OC (12GB)
Thermalright Frozen Edge 240 RGB
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/
use different variable name fo input_value like input_value1 , input_value2,input_value3
and after the first if statement use elif
like this
input_value1
if input_value1 == false :
whatever
input_value2
elif input_value2 == false :
whatever
input_value3
elif input_value3 == false :
whatever
if it was useful give it a like :) btw if your into linux pay a visit here
https://linustechtips.com/topic/1280488-python-help/#findComment-14297183
like this
*snip*
Let me try that
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/#findComment-14297188
Wait... now I am using the RPi.GPIO library, if I use those other variables, it’s now undefined so now what
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/#findComment-14297193
just use the output of library directly
dont add that input value thingy
https://linustechtips.com/topic/1280488-python-help/#findComment-14297200
How do I do that? I’m still kind of learning Python
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/#findComment-14297202
Like this?
GPIO.input(switchX, HIGH)
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/#findComment-14297209
Just now, mahyar said:
no
if gpio.input(switchx) == false :
I’m gonna try it... I’ll try to be back in 5 mins?
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/#findComment-14297213
btw use elif as i showed above
OK
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/#findComment-14297219
So I did elif statements and the terminal is still getting spammed by saying switch 3 is on
Is this code correct?
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/#findComment-14297224
well idk much more
i usually code this sort of stuff c/c++ those were only things i could see wrong with your code
https://linustechtips.com/topic/1280488-python-help/#findComment-14297229
I DID notice when I switched Switch 3 to True, it would stop, but the light switch is now inverted which will annoy me. Anything there?
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/#findComment-14297233
wait are you sure that led you are using is good? did you use pullup resistors? how are switches wired?
https://linustechtips.com/topic/1280488-python-help/#findComment-14297239
Let me draw it. This may take a while
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/#findComment-14297241
@mahyar K. Here it is. I am not using pullup resistors because they worked fine without, with no bouncing
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/#findComment-14297266
rpi has internal pullup resistors enablee them
https://linustechtips.com/topic/1280488-python-help/#findComment-14297269
How? sudo raspi-config? Or another bash command?
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/#findComment-14297270
Most of what I find is in Java. Do you mind sourcing the code for me? Sorry for being a pain, I’ll follow for your troubles with me
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/#findComment-14297284
That’s literally what I’ve just read 5 mins ago. It works well, no repeated echo. I would call this thread a success. Thank you for sticking around the 1 hour and 30 some minutes you did
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/#findComment-14297301
