Do you want to see the results on YT? I don’t mind making a video on it
EDIT: Now this thread will probably be locked for advertising
specs
ASRock B650I Lightning WiFi
AMD Ryzen 7 7700X
KLEVV CRAS V RGB (2x16GB) 6000MT/s out of the 7200MT/s I could be running
ASUS RTX 3060 OC (12GB)
Thermalright Frozen Edge 240 RGB
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/page/2/#findComment-14297304
3 minutes ago, TheCoder2019 said:
That’s literally what I’ve just read 5 mins ago. It works well, no repeated echo. I would call this thread a success. Thank you for sticking around the 1 hour and 30 some minutes you did
ok
it would be much easier in c but happy to hear it works
if it was useful give it a like :) btw if your into linux pay a visit here
https://linustechtips.com/topic/1280488-python-help/page/2/#findComment-14297324
And one more question... How do I print all the switches that are on in one line?
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/page/2/#findComment-14297327
there is a thing called quote button son
and can you clarify a bit
https://linustechtips.com/topic/1280488-python-help/page/2/#findComment-14297331
I want to use
print(All of the switches that are on)
Obviously All of the switches that are on is not a variable.
I want to print all active switches on one line instead of it being scattered in the terminal.
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/page/2/#findComment-14297334
Can I use something like this?
while True:
     if
     assign variable
     else assign variable
     elif
     assign variable
     else
     assign variable
     elif
     assign variable
Basically testing the value of the switches, assigning it to a list and printing it? Would that work?
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/page/2/#findComment-14297345
while True:
     if
     assign variable
     elif
     assign variable
     else
     assign variable
     elif
     assign variable
print(value1,value2,value3) use comma to separate them
https://linustechtips.com/topic/1280488-python-help/page/2/#findComment-14297355
Again, me being a noob, what is the variable value1- value3 assigned to
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/page/2/#findComment-14297359
1 minute ago, mahyar said:
whatever it is that you want to print
should write this for you?
Probably
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/page/2/#findComment-14297365
I feel stupid having someone write the code for me lol
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/page/2/#findComment-14297373
Just now, mahyar said:
print(GPIO.input(switch1),GPIO.input(switch2),GPIO.input(switch3))
just copy and paste this after last elif statement
OK thanks! I am truly sorry for torturing you...
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/page/2/#findComment-14297377
I might want to add a sleep timer because my console just got flooded
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/page/2/#findComment-14297388
Now I think we are officially done here
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/page/2/#findComment-14297394
It made my console look like a binary console because it is
specs
AMD Ryzen 7 7700X
Lian Li A4-H2O
linux packages
tmux
btop
git
https://linustechtips.com/topic/1280488-python-help/page/2/#findComment-14297401
