How many PWM fans can a motherboard take? Fan header splitting
12 hours ago, nutzaalex said:regardless of the exact value, if a header can do 1 amp max, it seems one can split a header quite a few times before it becomes a problem
since most motherboards come with more than 1 header, why do fan splitters from sata exist?
Be careful. Take the Noctua NF-A14 iPPC-3000, which pulls about .65A, and then you start to see the potential for problems. Just make sure what the max amperage is for each fan and that you don't go over the header limit unless you have a hub or controller.
15 hours ago, nutzaalex said:since most motherboards come with more than 1 header, why do fan splitters from sata exist?
Some people just want to have a powerful fan running, but they use more than 1A, so a hub or controller with a cable to the PSU resolves that issue .
