Is my dream triple channel ITX motherboard possible?
Just now, thDel said:I don’t understand, does am4 support quad channel? If not what CPUs do?
AM4 supports processors with a controller that has TWO memory channels, each memory channel allowing for TWO sticks. The first and third slot are connected to the first channel, the 2nd and 4th slot are connected to the second memory channel.
Motherboards with only 2 memory slots will simply connect only one memory slot to each channel available.
Threadripper supports 4 channels, and up to motherboard manufacturer if it connects 1 or 2 memory slots to each channel.
Threadripper Pro (like I linked) has 8 channels and I think only one memory slot per channel is usually found on motherboards (not enough space for 2, and it's way more difficult to have 16 slots)
