Browser, version and OS:
Chrome 86.0.4240.198
Windows 10, ver. 2004, build 19041.630
What happened?
No see delete comment button in Blogs
What did you expect to happen?
Want to return delete comment button in Blogs
Screenshots of the issue, if applicable:
https://linustechtips.com/topic/1276763-need-return-delete-comment-button-in-blogs/
Report the post, we will delete it for you.
13 minutes ago, revdv said:
But its my own space in Blogs - why I can't delete as in the past ?
easiest way is to edit the blog by random texts
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
Because, as part of the forum we have to ensure that the rules are followed in blogs as well as everywhere else, and allowing people to delete comments interferes with that. If you would like a comment to be deleted, you can report it and a moderator can delete it for you. Note however that we are unable to do that with private blogs, which I believe is the case for yours, and that is part of the reason that they are turned off for all new blogs.
HTTP/2 203
1 hour ago, ragnarok0273 said:
Why can't you delete your own posts?
as colonel mortis said
Quote
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
10 hours ago, ragnarok0273 said:
Makes no sense to me.
I get not deleting other people's posts, but not being able to delete your own sounds silly.
elephants
can't you hide your status updates and replies?
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
21 hours ago, revdv said:
I don't understand what you're asking here.
You can hide them, but that is distinct from deleting (because it remains accessible to mods). Blogs don't currently support allowing members to hide things, and this is the first time it has been requested.
HTTP/2 203
So why not just allow for 'deleting' replies/posts such as that only mods can see it. Or have some kind of cache where deleted posts/replies are kept and then automatically deleted after a period of time e.g. 30 days. It might be too much to ask but it's definitely not a bad idea.
It's not supported by blogs by default, and this is the only time that this has been requested so there doesn't appear to be much demand for it compared to other features that we could add. I am not saying that we won't add it, but adding features that will only be used by a couple of people, when there is a perfectly adequate alternative (reporting) is not high on our priority list.
HTTP/2 203
