In the market for a 27" Monitor
m1n1h4mm3rd
I've had a 24" LG e2441v monitor for almost 2 years and I'm looking to upgrade to a 27". Preferably something by Samsung, Asus or AOC.
Preferred secs:
27"
120Hz
1920x1080
Matte-finish screen
Can anyone recommend anything that they know is good? Thanks heaps in advance!
Madness can be a medicine for the modern world.
- Dr. Hannibal Lecter
Why 120hz?
I have a Samsung, it's pretty nice. It's their business model though so I don't believe it has speakers and it doesn't have HDMI.
I think they come in other configurations though.
It's S27C650.
It's not 120hz, though it goes up to 68? I think.
I don't think it'll be a huge issue with the card you have though, if you're playing current titles.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Benq XL2720T or its successor the Benq XL2720Z
I have the T version my self, and its awesome. It is a tn panel though, as is any 120Hz monitor, but it offers a lot of customization with colour profiles, emulating different screen sizes, acting as a usb hub, etc.
I'd recommend waiting for a G-Sync version though, if thats a factor for you.
You can check out Linus' unboxing of the 2420TE version, as its a very similar product.
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
  • 2 weeks later...
What is your budget?
Ignore price as a factor, I've learnt not to give myself a budget until I know roughly what to look for. :)   Sorry for the late reply.
Why 120hz?
Forgive me if this makes me sound newbish, but I'd like one that can display more than 60-70fps once I upgrade my GPU. I'm comparing my current 60Hz to my brother's 120, and good god mine feels more and more hideous.
Are you sure the feeling was from the change in refresh rate and not the change in the look of the panel itself?
Try a blind test with your brother's display at let him set different frequencies to see if you could even tell the difference.
Update:
His refresh rate was turned back down to 60Hz and straight away the 'choppiness' (for lack of a better word) was clearly visible with cursor movement.
Update:
That's pretty much it thought for me. I only notice a smoother cursor for the most part.
What about for actual gaming? Have you used a nice IPS panel before?
