Overheating r9 290x
Go to solution Solved by xnoobftw,
5 minutes ago, xAcid9 said:
Lower temp if you open the side panel? - If yes this indicate airflow restriction. If not then your cooler/heatpipe probably broken or didn't make proper contact.
Oh my god i did this and saw only 1 of 3 fans r spinning
guess that solves it!
rip 7 year old card
Hi guys, currently this is my setup as shown in the screenshot.
WHAT'S THE ISSUE
60c idle, 94c under load
Too toasty under load -> thermal throttling
WHAT I'VE DONE
1) Replaced r9 290x (Tri-X) thermal paste with MX-4
2) undervolted by -31mV in MSI AB
3) max fan speed at 55% (it sounds like a jet engine if its any higher)
4) core clocks and memory clocks are at stock (1040/1300)
Do you guys have any idea what may be the issue?
And another thing is should the top-front 140mm fan be an exhaust instead of an intake?
Thanks!
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/1270947-overheating-r9-290x/
I hope you cover the whole die with thermal paste and not using the pea/rice/line/x method.
https://linustechtips.com/topic/1270947-overheating-r9-290x/#findComment-14225818
60C at idle? Are you sure that the cooler is mounted properly and that the TIM was good and properly applied?
What are your ambient temps?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1270947-overheating-r9-290x/#findComment-14225822
rip 7 year old card
https://linustechtips.com/topic/1270947-overheating-r9-290x/#findComment-14225830
are you sure they are plugged in the pcb of the  gpu? try aftermarket cooler?
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1270947-overheating-r9-290x/#findComment-14225840
24 minutes ago, flo_306 said:
60C at idle indicates a broken cooler or poor contact
i have the same GPU in a PC and it doesnt get that warm in idle or load. But it does get pretty noisy since its getting very hot
your fan configuration looks good.
24 minutes ago, boggy77 said:
might have to push that up and live with the noise
Hi all,
So i found out that out of 3 fans, left (flushed to rear) is not working (i tried moving it with my hands it wasn't stuck or anything, just not moving)
center was working as per normal
right (flushed to front) was stupidly stuck cos my pci-e cable was jamming it, now it's working
WITH CENTER & RIGHT FAN
Idle = 60c
Load = 81c
is there a way to diagnose and fix the only fan that is not moving?
https://linustechtips.com/topic/1270947-overheating-r9-290x/#findComment-14225878
Hi all,
Idle = 60c
Load = 81c
The odds are the fan is defective, maybe you could get it fixed at a local repair shop, but don't count on it, try running the both good fans at 100%, ignore the noise for now and try it
https://linustechtips.com/topic/1270947-overheating-r9-290x/#findComment-14225889
6 minutes ago, xnoobftw said:
Hi all,
Idle = 60c
Load = 81c
If its not movin then its broken. Try to get it repaired at a local electronics shop. Gl m8
https://linustechtips.com/topic/1270947-overheating-r9-290x/#findComment-14225894
28 minutes ago, xnoobftw said:
Hi all,
Idle = 60c
Load = 81c
The tri-x 290 has a lot of fan failure but it's very easy to do the fan mod on it by using desktop grade fans making it cool better and be silent.
https://linustechtips.com/topic/1270947-overheating-r9-290x/#findComment-14225926
rip 7 year old card
remove the shroud and strap a couple of good 120mm fans.
https://linustechtips.com/topic/1270947-overheating-r9-290x/#findComment-14226120
