iCUE 4000X Fans?
Guiltyxz
I cant seem to figure out what fans are in the iCUE 4000X case. The website says "CORSAIR AirGuide RGB" and when I google them it comes up with SP120 RGB Pros. Some sources online say QL120 some say SP120. I just want to know if I get a 3 pack of SP120 RGB Pro fans will they connect to the RGB node and work with the included fans.
PC: Ryzen 7 2700 | RX 5700 XT | Asus Prime B450-PLUS | CoolerMaster Masterwatt 600W | 32GB Corsair Vengeance 3200MHz RAM | 512GB NVME SSD & 7TB combined HDD | macOS Monterey 12.6.6, Windows 7 Ultimate x64 and WIndows 10 Pro x64
Laptop: MacBook Pro 15" 2015 | i7-4870HQ | R9 M370X | 16gb | 1tb SSD
iPhone 13 Pro Max | 256GB | iOS 15.7
My Folding Stats | #MuricaParrotGang
according to this: https://www.legitreviews.com/corsair-icue-4000x-rgb-case-review_221937/2
They're SP120 Elite RGB fans.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
Thanks
uses an lighting node core basically it combine's the hub and the light node together. some may like the space saving other's wont. since it uses 4pin argb i don't think you can use there 3 pin strips with out an adapter...
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
