Module Not found error in python
Go to solution Solved by Wictorian,
Lol. The error was about my code.
What module are you trying to import?
____________________________________________________________________________________________________________________________________
pythonmegapixel
into tech, public transport and architecture // amateur programmer // youtuber // beginner photographer
Thanks for reading all this by the way!
By the way, my desktop is a docked laptop. Get over it, No seriously, I have an exterrnal monitor, keyboard, mouse, headset, ethernet and cooling fans all connected. Using it feels no different to a desktop, it works for several hours if the power goes out, and disconnecting just a few cables gives me something I can take on the go. There's enough power for all games I play and it even copes with basic (and some not-so-basic) video editing. Give it a go - you might just love it.
Just now, Wictorian said:
pyttsx3
Have you by any chance saved the file you're trying to import it from as pyttsx3.py?
If you've done that, then you need to rename it, as it creates conflicts (i.e. your program tries to import itself)
pythonmegapixel
nope. it is called simply "main.py"
2 minutes ago, Sakuriru said:
Where are you seeing this error? Take a screenshot.
We don't have any context with your problem. Is this an IDE? The program itself?
I ran the .py file by clicking on it and it didnt do anything. so I ran it in an IDE and it said pyttsx3 module not found.
OK. Could you do the following:
  1. Open the command prompt
  2. Type "python" and press enter
  3. You should see something like:
    Python 3.8.5 (Jul 20 2020, 15:57:54) [MSC v.1924 64 bit (AMD64)] on win32
    Type "help", "copyright", "credits" or "license" for more information.
    Check that the python version displayed is the one you expect. (In your case it should be similar to mine, as you say you're using 3.8)
  4. Type after the ">>>" symbol, "import pyttsx3"
If you do that, do you get the same error?:
pythonmegapixel
version is ok
I cant run the script you say, after importing, should I press some other key than enter?
I cant get it to run. it doesnt give any erros, just display another line with >>>
That's the correct thing to happen, don't worry. The import command doesn't produce any output.
So which IDE are you running it in?
pythonmegapixel
pycharm. normally I dont use an Ide. just use notepad. but when some bug happens, I handle it on the ide.
ok I'm really not sure what's causing your issue... sorry about that
pythonmegapixel
IF you are getting this error from within PyCharm the issue is likely with your interpreter.
You will need to ensure that the PyCharm interpreter has the module installed that you are wanting
To do this you can go under File/Preferences, then to Project:<your project name> and select Python Interpreter.
can go to the gear on the far right and click it and then the add option
From there you If you have installed the module to your system python and it is in fact working you can change the option on the left from Virtual
once you have done that then the import should work form inside of the PyCharm Python Console
I hope this helps
Cheers
Josh
Dragoby.com
