RTX 3080 20GB
Go to solution Solved by GoodBytes,
Yes. It is a known rumor that appeared before the 3080 was even released, this was reinforced by the fact that:
  • The 3080 only has 10GB of memory, while the 2080 Ti had 12GB
  • Once the card was released the PCB of the 3080, including the Founder Edition has 2 empty memory slots which means that a different memory configuration was designed since day 1. Normally, you never see this on a higher end card.
It is believed that Nvidia is probably holding the 20GB version as a potential reply to AMD, depending on their GPU performance and what consumer demands. If they feel there is no rush, then maybe 1 year from now they'll release a Ti version of it, that is a bit faster and 20GB of memory. If they feel the pressure from AMD, you may see the 20GB model early 2021.
Hey guys, has anyone heard the rumours around the RTX 3080 20GB? Word is they're slated for release around December.
https://videocardz.com/newz/nvidia-geforce-rtx-3080-20gb-to-launch-in-december
Here's hoping Linus can do a bit of an update video on the topic!
i7-10700k @ 5GHz 1.37v
ASUS ROG STRIX Z490-E GAMING
Corsair VENGEANCE® LPX 16GB (2 x 8GB) DDR4 DRAM 3200MHz C16
ASUS Dual GeForce RTX 2060 OC edition 6GB GDDR6 (+149MHz GPU / +1050Mhz Memory)
Fractal Design R5 Black
Samsung 970 EVO Plus 1TB NVMe 1.3 M.2
Samsung 860 EVO 1TB SATA
Corsair RM1000x 1000W PSU
LG 27UL600-W 27" 4K UHD HDR400 FreeSync IPS Monitor
Corsair iCUE H150i RGB PRO XT 360mm Roof Mounted
2x 140mm Be Quiet! Silent Wings 3 Front Fans
1x 140mm Be Quiet! Silent Wings 3 Floor Fan
1x 120mm Corsair SP120L Side Fan
1x 120mm Corsair SP120L Rear Fan
Corsair K68 RGB
Logitech G502 HERO
Logitech Z623 2.1 Speakers
Windows 10 Professional x64
https://linustechtips.com/topic/1258503-rtx-3080-20gb/
doubt they'll cover rumors
at most, probably the WAN show
but i don't see a point of this, not like we can get it even if we know it exists/launch date
just like anything else, wait for launch and benchmarks
knowing it exists wont suddenly turn 3080 10gb card into un-usable junks either, it just means more options are available.
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/1258503-rtx-3080-20gb/#findComment-14124016
rumours of it appeared pretty much as soon as we know the current 3080 only has 10G VRAM. Even proposed its launch to be some time after Big Navi's. Honestly if they think this is worth going over, they would have.
Desktop benching:
https://linustechtips.com/topic/1258503-rtx-3080-20gb/#findComment-14124023
of course. just keen to hear more I guess!
Corsair K68 RGB
Logitech G502 HERO
https://linustechtips.com/topic/1258503-rtx-3080-20gb/#findComment-14124024
as i've said, it's pointless
i'd rather hear about a product that i can actually get my hands on, than speculations and what not, unless it's confirmed facts (which seldom happens unless nvidia themselves released info)
hyping is unhealthy, and pointless.
https://linustechtips.com/topic/1258503-rtx-3080-20gb/#findComment-14124029
Not hyping - but your attitude says a lot about you though :)
Corsair K68 RGB
Logitech G502 HERO
https://linustechtips.com/topic/1258503-rtx-3080-20gb/#findComment-14124034
if you really need that much vram you could just buy a 3090 and get its added minor performance bonus.
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1258503-rtx-3080-20gb/#findComment-14124038
all depends on the price then I guess hey
Corsair K68 RGB
Logitech G502 HERO
https://linustechtips.com/topic/1258503-rtx-3080-20gb/#findComment-14124043
tbh the average gamer doesnt need this even if it was at a reasonable price for the spec. its kinda like a post i saw a while ago where this kid wanted to put threadripper in epyc. useless and a waste of money if you cant take advantage of it.
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1258503-rtx-3080-20gb/#findComment-14124054
fair - it'll be interesting how much stock of the next batch of 3080's appear, what with the rumours of nvidia holding back stock deliberately and all that.
Corsair K68 RGB
Logitech G502 HERO
https://linustechtips.com/topic/1258503-rtx-3080-20gb/#findComment-14124060
very true
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1258503-rtx-3080-20gb/#findComment-14124065
That would be wild for them to come out with a variant so quickly. With the way people are going nuts for the cards now, if I were an early adopter I would be filled with nothing but rage if this turns out to be true. Jensen and myself would be throwing hands.
Leonidas Specs: Ryzen 7 5800X3D | AMD 6800 XT Midnight Black | MSI B550 Gaming Plus | Corsair Dominator CL16 3200 MHz  4x8 32GB | be quiet! Silent Base 802
Maximus Specs: Ryzen 7 3700x | AMD 6700 XT Power Color Fighter | Asrock B550M-Itx/AC | Corsair Vengeance CL 16 3200 MHz 2x8 16 GB | Fractal Ridge Case (HTPC)
https://linustechtips.com/topic/1258503-rtx-3080-20gb/#findComment-14124085
Nothing new Nvidia screws up their loyal followers.
https://linustechtips.com/topic/1258503-rtx-3080-20gb/#findComment-14124123
why though?
did you get anything less than what you paid for? or?
https://linustechtips.com/topic/1258503-rtx-3080-20gb/#findComment-14124124
it's a very solid rumor at this point, but it's gonna launch at 900usd, the 10gb is still a better deal since it's the same amount of cuda cores, unless you can REALLY use the extra vram.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1258503-rtx-3080-20gb/#findComment-14124156
https://linustechtips.com/topic/1258503-rtx-3080-20gb/#findComment-14124414
3 hours ago, Moonzy said:
why though?
You're missing the point completely. This isn't like the Super cards or something that came out down the line. We're talking less than 3 months if the rumors of December are true. That's 100% absurd. But as the above poster stated, that's nothing new with Nvidia apparently, lol.
https://linustechtips.com/topic/1258503-rtx-3080-20gb/#findComment-14124509
I keep seeing this argument made, while the 3080 isn't the successor for the 2080 TI but rather the 2080 which had 8GB's of VRAM.
I do suspect a "3080 TI" like card will have more than 12GB's of VRAM.
However such a card shouldn't outperform the 3090, and the 3090 is only marginally better than the 3080 with much more VRAM.
In the end the question would be, if the 3090 is only marginally better than the 3080 but due to it having 24GB's of VRAM it costs more than double in MSRP
How much would they charge for 20GB's of VRAM?
I honestly doubt they will kill their 3090 months after it releases, so I do expect a potential 20GB version to be 1000$ or higher.
At that price range one can start asking the question, is such a price worth it?
At 4K most likely, but at 2K or even 2,5K it's not likely we will pass beyond 10GB's of VRAM before you can replace the 3080 with something better at which point the money saved would go well into a new card.
We have seen higher VRAM version of cards before, and by the time it was relevant to 90% of the consumers the cards had some years on them.
https://linustechtips.com/topic/1258503-rtx-3080-20gb/#findComment-14124778
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
https://linustechtips.com/topic/1258503-rtx-3080-20gb/#findComment-14124918
From all the testing I've done you will likely need to do one of the following to have issues with 10GB.
Run 4k AND a) "next gen" settings in some games or b) custom texture packs
Although some really high end extreme texture packs will make it an issue at lower resolutions as well.  The good part is most of the settings that push you over are likely indiscernible from dropping textures to Ultra or high.  For instance 4k Doom Eternal needs about 9GB on "nightmare" but its less than 8GB on "Ultra".
AMD 7950x3D / Gigabyte Aurous Master X670E/ 64GB @ 6000c30 / 3 x 4TB Samsung 990 Pro / 44TB Synology 1522+ / MSI Gaming Trio 4090 / EVGA G6 1000w /Thermaltake View71 / LG C1 48in OLED + MSI 321URX - Moved back to air cooling Phantom Spirit 120 SE.  Server (PLEX) - 155H NUC 64GB  and 60GB Optane drive/ Server (AI) 64GB M4 Max Mac Studio
https://linustechtips.com/topic/1258503-rtx-3080-20gb/#findComment-14125121
