4K Monitor - 60Hz or 144?
Mondas42
Morning
I’m thinking of treating myself to a 4K monitor to compliment my 3080 Strix (when I get it!!). I’m torn between a ASUs TUF 28inch 60Hz model for about £360 or the much more expensive ASUS Strix 27inch 144hz one which is about £800. I’m a casual gamer but like good graphics etc. Would I be ok with the 60Hz model or would I be better off saving up for the more expensive one? Would I really see the difference do you reckon?
thanks,
Martin
60hz isn't even good gaming experience, you are better off saving up for the 144hz, or even a 120hz
PLEASE TAG ME SO I CAN SEE YOUR REPLY!
CPU: AMD Ryzen 7 3700x  | Motherboard: Asus TUF X570 Plus | RAM: Crucial Ballistix 8gbx2 3600Mhz | GPU: Asus TUF RTX 3080 | PSU: NZXT C850 | Case: Corsair 5000D AF | Cooler: NZXT Kraken Z63 280mm | SSD: Samsung 970 EVO 500Gb m.2 ssd + Samsung 860 EVO 1tb ssd | Monitor: LG 49WL95C-W | Peripherals: Logitech G815 + Razer Viper Ultimate + Razer Kraken TE | Audio: Logitech G560
Why not go for the middle ground with a 144hz 1440p 27"?
Imo that's a perfectly fine resolution for the size.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
butttt it's a 3080 so...
Gaming on 60hz is so much worse than 100hz+.
I think 1440p 144hz is the sweet spot for price and performance.
Does the monitor have to be 4k?
My Gaming PC:
Inno3D iChill Black - RTX 4080 - +500 Memory, undervolted Core, 2xCorsair QX120 (push) + 2xInno3D 120mm (pull)
AMD Ryzen 7 7800X3D - NZXT x72
G.SKILL Trident Z @6000MHz CL30 - 2x16GB
Asus Strix X670E-E Gaming
1x500GB Samsung 960 Pro (Windows 11)
1x2TB Kingston KC3000 (Games)
1x1TB WD Blue SN550 (Programs)
1x1TB Samsung 870 EVO (Programs)
Corsair RM-850X
Lian Li O11 Vision
ASUS ROG Swift OLED PG27AQDM (240hz OLED), MSI Optix MAG274QRFDE-QD, BenQ ZOWIE XL2720
Logitech G Pro Wireless Superlight
Wooting 60HE
Audeze LCD2-C + FiiO K3
Klipsch RP600-M + Klipsch R-120 SW
My Notebook:
MacBook Pro 16 M1 - 16GB
Proxmox-Cluster:
  • Ryzen 9 3950X, Asus Strix X570E F-Gaming, 2x32GB3200MHz ECC, 2x 512GB NVMe ZFS-Mirror (Boot + Testing-VMs), 2x14TB ZFS-Mirror + 1x3TB (TrueNAS-VM), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), 10G NIC
  • i7 8700k delidded undervolted, Gigabyte Z390 UD, 4x16GB 3200MHz, 1x 512GB SSD (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), 2,5G NIC
  • i5 4670, 3x4GB + 1x8GB 1600MHz, 1x 512GB SSD (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), 2,5G NIC
Proxmox-Backup-Server:
  • i5 4670, 4x4GB 1600MHz, 2x2TB ZFS-Mirror, 2,5G NIC
I wouldn't go for that asus 4k144hz. There is an lg 4k144hz monitor that is I think 700 USD. That may be worth taking a look at. Other than that I wouldn't look at current 4k144 monitors since they're due for a replacement soon. As other people have said take a look at some 1440p 144 or 240hz options
Going 4K on a 27" monitor for gaming doesn't make sense imo. I'd rather go with 1440p and take the much better FPS than with 4K.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
Soooo you can actually get 144hz in virtually any game at full details which is.... Bad?
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
you would really see the difference, the question is: if you're a casual gamer, do you want to double the budget for that?
i wouldnt say gaming is as much of a problem as the rest of the things you'll be doing on the machine.
display scaling is still arse with some programs, and 4k on 27" is too small if you're not putting your display RIGHT in front of your nose. i'd say for most people 1440p on a 27" is ideal for a "healthy" distance. dropping down to 1440p also puts you in a more affordable price bracket.
i'll put it like this: for the price of the 4k144Hz panel, you could get a 1440p 144Hz panel (whatever first hit i found on google), and a new set of nice 'gaming' peripherals.
And enjoy your gpu longer before having to drop the settings
Don't get anything lower than 120Hz it's just so bad. Even when buying cheapest new monitor for a new PC.
| Ryzen 7 7800X3D | AM5 B650 Aorus Elite AX | G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | Sapphire PULSE Radeon RX 7900 XTX | Samsung 990 PRO 1TB with heatsink | Arctic Liquid Freezer II 360 | Seasonic Focus GX-850 | Lian Li Lanccool III | Mousepad: Skypad 3.0 XL / Zowie GTF-X | Mouse: Zowie S1-C | Keyboard: Ducky One 3 TKL (Cherry MX-Speed-Silver)Beyerdynamic MMX 300 (2nd Gen) | Acer XV272U | OS: Windows 11 |
The LG mentioned above is the LG 27gn950, which hardware unboxed are trying to review soon. It looks good on paper, but has had availablity issues since it was released roughly April time.
If you can wait till after Christmas, alot of people have been mentioning we should see alot more 4k 144hz monitors coming out by then.
  • 3 weeks later...
Decided not to bother with 4K as I’m gaming at a desk and also use the computer for other stuff such as writing. So I went for a 240hz 1440p monitor instead.
